Ive downloaded several full bins for Win64 and ran -filters and none so far show is supports nlmeans_vulkan....
however....
It shows it in the filter base of ffmpeg... at...
https://ffmpeg.org/ffmpeg-filters.html#nlmeans_005fvulkan
So, now I am confused...
Thoughts/experiences??
	The media-autobuild suite may help you doing that using a very configurable and self-updating MSYS2/MinGW environment.
 There is just a chance that some developer just messed up the sources of a linked module to not build properly at the moment, so the process might fail from time to time ... until they fix it or the suite implements a temporary workaround, e.g. falling back to an older source snapshot which still worked.
	Try at https://www.gyan.dev/ffmpeg/builds/ - seem full release is build with vulkan support
 Thanks! I *finally* got it to work with vob source (720x480) using:
 However, I am only getting 14fps encode with GTX 1050TI. Using HandbrakeCLI's NLMeans, I was encoding at 200fps (both with NVENC_HEVC)Code:-init_hw_device opencl=gpu:0.0 -filter_hw_device gpu -filter:v "hwupload,nlmeans_opencl,hwdownload,format=yuv420p"
 I need to dig into this more, but Ill stick with HB until I can figure out a better way to get FFMPEG to work.
 Thanks again!
 Andrew
	After doing some more digging, I added the arguments to the filter as suggested at:
 https://forum.videohelp.com/threads/398880-Optimising-Performance-of-NLMeans-in-FFmpeg
 and am now getting 280fps encode...
 Ive got some experimenting to do!!!
 Thanks for everyone's help, esp. pandy!
 Andrew
  How to make the next subtitle appear below the current one and not aboveBy Skyflakes in forum SubtitleReplies: 8Last Post: 7th Nov 2021, 08:50
  current DVR options?By guthrie in forum DVD & Blu-ray RecordersReplies: 12Last Post: 1st Feb 2021, 13:05
  PotPlayer copy either current subtitle timestamps OR current audio clipBy Sakusuke in forum Software PlayingReplies: 0Last Post: 29th Aug 2020, 13:35
  .vhs to MP4 or any currentBy scotsue in forum Video ConversionReplies: 1Last Post: 1st May 2019, 09:39
  Current PAL/NTSC DVD Conversion Guide? Current Guides are outdatedBy isj209h23h in forum User guidesReplies: 3Last Post: 20th Jul 2018, 22:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
