Hi everyone. I am having an issue with my blu-ray drive.
My blu-ray drive model is: LG WH14NS40.
As the title states, I just flashed it using the SDFTool flasher and with patched firmware. Windows recognises my drive and so does MakeMKV (no issues there). MakeMKV also now mentions that LibreDrive drive is enabled. The main problem is that now I can no longer get the disc tray to open (it could open before I flashed the drive). The only thing that does happen when pressing the eject button is the light on it flashes for a couple of seconds.
I appreciate any advice given to fix this issue.
Results 1 to 13 of 13
Longshot, but did you power off your pc, wait a few minutes and then restart?
The firmware maybe correctly flashed but not loaded, a power cycle may fix that. -
There's a small hole near the eject button, push a hairpin in it and it will open the drive, press the eject button to see if it starts working again. Why did you mess with a brand new drive? did it stop functioning?
Flashing the drive gives it the option to recognize and rip uhd blu-ray discs.
that's a fairly old drive. sometimes the tray gears get sticky. try pushing the button and prying the sides open with tiny screwdrivers.
I have the same drive and patched it and it works with no issues.
So I tried the hairpin thing on the blu-ray drive, and it didn't seem to want to open. To answer your functioning question, I don't think it stopped functioning completely? If it did, I don't think the light on it would blink on and off when I try to eject the tray.
Might want to check to see if the There's any door movement at all,not sure if that model uses a rubber belt to move it.
Tray Won't Open
By Gregavi in forum DVD & Blu-ray PlayersReplies: 1Last Post: 30th Oct 2021, 20:49 -
Sony BWU-500S Desktop Blu-Ray drive Won’t Read
By chane in forum DVD & Blu-ray WritersReplies: 2Last Post: 2nd Feb 2021, 15:35 -
My blu ray's won't play !
By themaster1 in forum Blu-ray RippingReplies: 5Last Post: 30th Jul 2020, 09:04 -
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 14:44
