No, there are small jumps in the motion for FillDrops.Mp4 (it improved over the original, but it's not smooth, and technically wrong)
Filldrops will produce judder on content that was 25p and converted to 30p by inserted duplicates (ChangeFPS type conversion) - it's mathematically incorrect. The space/time "distance" of interpolated frame will not match the distance space/time other surrounding (original) frames
Filldrops would be correct approach if a frame was dropped, and an inserted duplicate took the same location (hence the name "filldrops"), this would give the correct "equal distance between frames" .
I'll try to explain more clearly, or show a more clear demo /graphic with linear motion if it doesn't make sense
Results 31 to 37 of 37
Hmm,... okay. Not totally sure it get 100%, but enough that I see your point.
So the only good solution would be to use SelectEvery (if the pattern, of the repeated frame, is fixed) or (T)Decimate (if the pattern might/does change).
Thanks for your patience.
Cu Susers currently on my ignore list: deadrats, Stears555, marcorocchini -
On original 25fps content, each frame is 40ms apart (1/25 = 0.04), "equally spaced apart" in terms of time and distance
A ChangeFPS style conversion to 30fps inserts a duplicate every 5th ,6th frame .
The motion of the original frames' content doesn't change . If an object from the original 25fps sequence moved linearly, say 10 pixels to the right per frame, it would go 0,10,20,30,40,50,60 in terms of x-position
After ChangeFPS, it the x-position would look like (where the 0,0 and 50,50 are the inserted duplicate frames; or it might be slightly different depending on where in the cycle you are counting from)
0,0,10,20,30,40,50,50,60,70....
After filldrops, the 2nd frame of the duplicate pair will be interpolated from the frame before and after. An "inbetween" frame 50/50 distance between the 2 neighbors
0,5,10,20,30,40,50,55,60,70...
The distance for the "5" and "55" are half the distance compared to the "normal" frames which have a delta distance of 10. This will appear as judder, because the object that originally moved linearly , will speed up and slow down -
Nice, thanks for the detailed explanation.
You usually don't need to do anything except put this:
just before the TDecimate call.Code:TFM()
This is my basic IVTC script to go from 29.97 interlaced NTSC telecined material to 23.976 progressive.
(Always make sure you get the field order correct when doing IVTC.)Code:AssumeTFF() tfm(display=false) tdecimate(cycleR=1,cycle=5) #defaults are cycleR=1 and cycle=5
From the Wiki: "TFM is a field matching filter that recovers the original progressive frames from a telecined stream."
If the telecine pattern has variations, TFM will provide hints to TDecimate so it adapts.
I have not tried it on your source, so I don't know if it will fix your problems, but since it takes five seconds to add "TFM()" to your script, you should at least try it. -
John, I added TFM but to my untrained eye I couldn't spot any difference. I think my video is a simple case of, consistently, an extra frame every 5, so cycle 6 has fixed it nicely.Originally Posted by Johnmeyer
@Selur, I think that was what I was trying to say when I incorrectly described it as variable speed. Stepping through with the arrow keys, the movement just seemed to be a bit variable.Originally Posted by Poisondeathray
Repeat every 5th frame
By pooksahib in forum Video ConversionReplies: 4Last Post: 12th Mar 2023, 08:00 -
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
Disabling Auto-Repeat Feature in Freemake Video Converter
By TheRockSnob in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2020, 21:20 -
How do I fix my movie's frame rate?
By Fez in forum Newbie / General discussionsReplies: 5Last Post: 12th Dec 2018, 12:39 -
Every 6th frame is duplicated
By jorge69696 in forum Video ConversionReplies: 13Last Post: 29th Oct 2018, 12:27
