Quick update version 4 is available as a download
link
https://av.jpn.support.panasonic.com/support/global/cs/e_cam/download/x2000/index2.html
Thread: Panasonic Hc-X1500/2000
Having tried out the slow motion setting on this camcorder it only works on the first slot so backup as slot 2 is shut down.
It would have been more advantage if they had made the remote feature to also make it into on/off wirelessly
Sony did it on their FDX AX53 model via a third party wireless remote switchLast edited by realspeed; 11th Jul 2023 at 01:46.
for anyone who might do their own videos this is my table top rig. The Sirui SLK-200 extn arm extends up another 5" if needed
from bottom to top
Moman tripod legs
Manfrotto befree handle with wired remote for zoom /start/stop but no on/off switch
Panasonic HC _X1500
panasonic HC-X1500 top handle
Panasonic VW -VMS10 Microphone
I have added a bluetooth transmitter ( shown below the XLR ports) wired into the camcorder output mike port at the back and the mike into the camcorder input port. Now I can by using a bluetooth headset I can test sound without being tethered to the camcorder from any position.
To tidy it up a bit more just ordered a 2.5mm male to male 3 pole 7" straight cable to replace the existing curled oneLast edited by realspeed; 3rd Jan 2024 at 07:40.
Panasonic HC-X1500 with bluetooth dongle tryout
By realspeed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th May 2023, 04:59 -
Panasonic HC-X1500 light increase
By realspeed in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2022, 11:08 -
New microphone for Panasonic HC-X1500
By realspeed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Apr 2022, 11:16 -
Panasonic HC-X1500 first impressions
By realspeed in forum Newbie / General discussionsReplies: 13Last Post: 15th Mar 2022, 07:56 -
Panasonic Hc-X1500 portable lighting
By realspeed in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2022, 19:00
