hi i'm trying to back up a childrens dvd that contains 10 episodes, what i want to know is how to get all the episodes together on 1 svcd using dvd2svcd.When i select the vob to rip can i select multiple vobs as all 10 episodes are separate vobs on the dvd?I not that new at dvd2svcd but this has got me stumped as it will take ages to convert them all separately.there must be an easy way please... BILKO1
i haven't use dvd2svcd so i may not be that helpful...
is there some kind of batching encoding offered in dvd2svcd..if it is, you can just do all 10 at a time
another way...but prolly not that good of an idea is to but al the vobs as a set...
i.e. if episode 1 is vts01_1.vob and episode 2 is vts02_1.vob...wut you can do is rename the episode 2 vob file as vts01_2.vob...
this will trick dvd2svcd into thinking all the vobs are together in a set...when you encode, however, the episodes will be linked together, so you may need to cut the resulting .mpg into the episodes you want..
btw, i believe you can only link 9 vob files together (i.e. last vob file in the set would be vts01_9.vob) -
no actually you can now link up to 255 vobs with the cliDVD2AVI version dvd2svcd customized which is used in the program.
Thanks for the replies
mrbass will any version of dvd2svcd do this or just the latest? i'm using 1.0.6 as i tried a later version and had lots of problems..
How to play multiple VOBs and a subtitle file
By kenj in forum Software PlayingReplies: 3Last Post: 22nd Jun 2010, 18:42 -
Free Software to rip multiple PGC's in one hit to individual vobs
By Ads79 in forum DVD RippingReplies: 2Last Post: 24th Apr 2010, 05:25 -
Joining multiple VOBs to make one AVI?
By RedCorvus in forum EditingReplies: 4Last Post: 6th Aug 2009, 10:57 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 12:25 -
Multiple DVDs/VOBs...
By takearushfan in forum Authoring (DVD)Replies: 6Last Post: 26th Aug 2007, 06:39
