Hello people,
My friend sent me a Super8 scan that was done by a company. I've been trying to remove duplicate frames because it messes up the whole restoration, not sure they knew what they were doing.
Please, could you help me? I put two samples down below.
Thanks!
That is an incompetent scan and your friend should ask for his/her money back. It looks like they used one of those old Goko transfer units which utilized a rotating prism. You ended up with almost every frame blended.
You could try playing around with SRestore, and you can look at this technique:
The power of AVISynth salvaging "botched" transfers of old 8mm films to DVD.
but both of them assume that you have more "good" frames to use as the basis for their fixing.Last edited by johnmeyer; 2nd Jun 2023 at 14:18. Reason: removed AVISynth automatic URL which screwed up MY URL
Duplicate Frames or???
By salvo00786 in forum DVD RippingReplies: 13Last Post: 3rd Oct 2022, 13:07 -
Removing all duplicate frames in a video clip
By ecortez in forum EditingReplies: 0Last Post: 10th Mar 2021, 20:23 -
Duplicate frames issue
By tupper in forum Video ConversionReplies: 1Last Post: 18th Dec 2019, 11:04 -
On x264's Handling regards Consecutive Duplicate Frames
By gdgsdg123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2019, 18:26 -
H.265 introducing duplicate frames
By ZetaStax in forum Video ConversionReplies: 22Last Post: 2nd Aug 2019, 14:58
