There is an original video (MediaInfo) my family:
Tell me please, is it important to add these options to ffmpeg when encoding:
?Code:-color_range pc -color_primaries bt709 -color_trc 1 -colorspace 1
Or is the usual bitrate reduction enough?
Original video does not contain bt709, color_range (0-255), etc.Code:-b:v 6000k -maxrate 6000k -minrate 6000k -bufsize 90000k
I can't figure, out if FFmpeg will leave it as it is, barely touching the original video (without ruining it), or if it's worth specifying the commands.
Help please.
Yes, worth adding. Even though it should be interpreted as BT.709 by default.
The default is limited and that should be the information (-color_range tv). But whether it is actually limited range or full you should check.
SVEN IC-350 webcam and ffmpeg - I/O error
By Viacheslav in forum Capturing and VCRReplies: 2Last Post: 5th Apr 2021, 04:49 -
Download HLS video using FFMPEG with separate video and audio URLs?
By oschrndz in forum Video Streaming DownloadingReplies: 2Last Post: 15th Dec 2020, 13:53 -
Can ffmpeg be used to test my NB505 laptop's webcam from its core?
By Chemist116 in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2020, 18:04 -
A good software to capture and record video from webcam.
By prankstare in forum Video Streaming DownloadingReplies: 10Last Post: 12th Dec 2018, 21:40 -
Can phone video connect and work through pc webcam?
By mikehende in forum Newbie / General discussionsReplies: 5Last Post: 4th Dec 2018, 10:52
