While I was (mostly) able to recreate VHS effect using only software, what I couldn't do is replicate the audio. Every time i try it tends to sound too sterile.
Now is there a way to have audio with a quality similar to this one: https://www.youtube.com/watch?v=u5xt5WG7tt0
using only PC software?
All that clipping and distortions
Apply lowpass filter around 6..7kHz, peak bass, add noise so overall SNR will be around 42..46dB, clipping and distortions can be results of poor audio capture (analog tape should have no resonance or colorization similar to one in video from link - it sounds like aliasing - but also it can be problem with mixing horizontal sync frequency with sampling rate)
I knew how to do the first two, but I am still confused as to how one could do the aliasing or whatever that effect could be. I tried audacity distort however it sounds like it came from a terrible microphone then. Maybe adobe audition can help?
Not sure if Audition will be any gain over Audacity - you may try to use some filters to 'crush' and distort sound then blend original with distorted in ratio you like.
You can also use for example SoX and 'downsample' filter to efficiently introduce decimation without proper filtering... also you can try to search for some VST plugins - some of them are free and may do distortions you willing to achieve.
https://bedroomproducersblog.com/free-vst-plugins/bpb-dirty-filter/ and many similar to this one.
How to achieve the quality of X264&X265 2pass slow with NVENC HEVC?STAXRIP
By Comparison in forum Video ConversionReplies: 10Last Post: 10th Jun 2020, 15:39 -
Save Settings for VHS Conversions for Best Audio Sync and Quality Picture
By myladydeb in forum Newbie / General discussionsReplies: 6Last Post: 2nd Feb 2020, 23:09 -
How to achieve this?
By joeltheyap in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2020, 00:30 -
Vhs audio quality
By trackermkel in forum AudioReplies: 3Last Post: 15th Jan 2019, 14:46 -
How do I achieve the cinematic look for videos?
By Anonymous754 in forum Newbie / General discussionsReplies: 18Last Post: 12th Nov 2018, 20:09
