Hello
i have avermedia c874
using windows 10 64bit
i have original dvd instalation of this capture's device
in windows in device manager i have installed it, show
"avermedia c874 USB HD Capture(Master)" and
"avermedia c874 USB HD Capture(Slave)"
both device's driver 1.0.64.22
[Attachment 71360 - Click to enlarge]
so i use
totalmedia extreme 2 to capture
detect capture but don't let me choose the input (composite rgb or s-video)
only show this
[Attachment 71359 - Click to enlarge]
instead an alternative that I came up with
install windows xp 64bit in a virtual box machine
so there enable avermedia trough usb conection in virtual box
the capture work perfect using the same method
let me choose the input and can grab capture
[Attachment 71361 - Click to enlarge]
but i wish have a solution for use in windows 10 and not have to use a virtual machine
thanks
edit: Solved using a usb pci-e card
maybe the problem is the drivers chipset of motherboard is not compatible with avermedia card
Windows 10 update has rendered USB 2861 Capture Device unstable
By makeshift in forum Capturing and VCRReplies: 3Last Post: 3rd May 2023, 10:52 -
Panasonic NV-GS75 usb capture windows 10
By jamespoo in forum Capturing and VCRReplies: 4Last Post: 2nd Sep 2021, 03:56 -
compile vs-placebo for Windows 64bit?
By Selur in forum ProgrammingReplies: 3Last Post: 19th Jul 2021, 15:27 -
Software AverMedia C874
By Darient Flores in forum Capturing and VCRReplies: 1Last Post: 22nd Apr 2020, 03:45 -
Is there somewhere I can download FFMPEG with x264 for Windows 7 64bit?
By Livingonvideo in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2020, 20:13
