    May 2023
    Egypt
    can someone tell me how i can download that url : https://almen-almentormedia-euno.streaming.media.azure.net/30c55259-62e4-4bbe-a798-9cc...ncryption=cenc)
    its says protected by DRM
    Really, I will not forget this favor, thank you
    i use this come on streamlink.exe
    C:\Users\Reko\Desktop\streamlink-5.5.1-2-py311-x86_64\streamlink\bin>streamlink.exe "dash://https://almen-almentormedia-euno.streaming.media.azure.net/30c55259-62e4-4bbe-a798-9cc1faf89838/main.ism/manifest(format=mpd-time-cmaf,encryption=cenc)" best -o video.ts
    [cli][info] Found matching plugin dash for URL dash://https://almen-almentormedia-euno.streaming.media.azure.net/30c55259-62e4-4bbe-a798-9cc1faf89838/main.ism/manifest(format=mpd-time-cmaf,encryption=cenc)
    error: https://almen-almentormedia-euno.streaming.media.azure.net/30c55259-62e4-4bbe-a798-9cc1faf89838/main.ism/manifest(format=mpd-time-cmaf,encryption=cenc) is protected by DRM
    May 2023
    Egypt
    sorry but i realy didnt understand well what to do i need some help
  3. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    You need to read the information that those sticky threads provide.
    Learn how to find the MPD URL, the PSSH, License URL (and headers if needed)
    Then dump a CDM or (if your license server is supported by CDRM-Project) find the key that way. The dumping of a CDM from Android Studio is also a sticky thread
    Download the video, decrypt using mp4decrypt of shaka-packager and merge the decrypted files into a single video file.
    I know it's a lot but if you're not willing to at least look into the basics, you are already lost.
    May 2023
    Egypt
    you are right i realy dont know the basics im willing to learn buts its so hard for me to undertand this in english lang
    i search on youtube to see some videos to understand in my lang but i didnt find so i find this place doing methoed to download some videos. i know its not easy I was hoping to find a someone make a video to follow just a methoed for my url
    you are right thanks .
  5. The DRM is Widevine L3.
    The first step is to get the PSSH and License URL which are inside the URL you provided.
    <cenc:pssh>AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEO/vRMcRnEKDod6mYJZ0A3g=</cenc:pssh>
    <ms:laurl licenseUrl="https://almentormedia.keydelivery.northeurope.media.azure.net/Widevine/?kid=efef44c7-119c-4283-a1de-a66096740378"/>
    To key decryption keys you can use https://cdrm-project.com/ providing the aforementioned values.
    After this download N_m3u8DL-RE and invoke the program with thiscommand line:
    N_m3u8DL-RE.exe "https://almen-almentormedia-euno.streaming.media.azure.net/30c55259-62e4-4bbe-a798-9cc1faf89838/main.ism/manifest(format=mpd-time-cmaf,encryption=cenc)" --save-name test -M mp4 --key [put output of the website above]
    After all this you should have a file named test.mp4 that you can play.
    May 2023
    Egypt
    thanks alote mate !!! its work realy Thank you so much for your time and valuable advice
