Can I get help with the following keys:
1)
URL:MPD:Code:https://www.vrt.be/vrtmax/livestream/video/ketnet/PSSH:Code:https://live.vrtcdn.be/groupb/live/eaa4602e-e35d-426d-8e36-91d814cabd39/live.isml/.mpdLicense:Code:AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEJ/9/mFP5mk/iZMBkEg8+y1I49yVmwY=Code:https://widevine-proxy.drm.technology/proxy
2)
URL:MPD:Code:https://www.vrt.be/vrtmax/livestream/video/vrt-canvas/PSSH:Code:https://live.vrtcdn.be/groupc/live/14a2c0f6-3043-4850-88a5-7fb062fe7f05/live.isml/.mpdLicense:Code:AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEEEYM2drry6aEDu8L2OC+UxI49yVmwY=Code:https://widevine-proxy.drm.technology/proxy
Thank you
Closed Thread
Results 361 to 390 of 554
Hi, need help. I use this PSSH that i get from MPD and enter it in keysdb.net.
licence: i search with F12 and find only https://licensing.bitmovin.com/licensing which I read around here is not correct one (it also gives an error when trying to get keys), so I use recommended one instead:Code:AAAAV3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADcIARIQDwh9qhRDTY29p8b4c18UmBoLYnV5ZHJta2V5b3MiEA8IfaoUQ02NvafG+HNfFJgqAkhE
I get success and 5 keys.Code:https://cwip-shaka-proxy.appspot.com/no_auth
like so:
[Attachment 77904 - Click to enlarge]
However after trying one by one and also chaining them together I get error in shaka packager:
none of key_ids returned by keysdb.net (I also tried crdm-project) include 0f087daa14434d8dbda7c6f8735f1498.Code:Error retrieving decryption key: 14 (INTERNAL_ERROR): Key for key_id=0f087daa14434d8dbda7c6f8735f1498 was not found
why not? In the end I tried searching in "getWvkeys" database on discord and I get a cached return with single correct key_id:key combo, which I use to decrypt the video succesfully.
however I dont want to rely on a lucky database search, so what am I doing wrong here?Code:0f087daa14434d8dbda7c6f8735f1498:4ac9e3307c7ed6456c0a933bd46c0fdd
@obo already told you how to find the pssh. Get the init.mp4
and run this scriptCode:yt-dlp.exe MANIFEST --test --allow-u
https://forum.videohelp.com/threads/405001-How-to-get-the-widevine-pssh-from-init-mp4-...pt#post2688829
You can't find the pssh in the mpd. But you can get it if you download the first fragment by using that mpd.--[----->+<]>.++++++++++++.---.--------.
So, from Windows: cmd as admin
yt-dlp.exe https://live.vrtcdn.be/groupc/live/8edf3bdf-7db3-41c3-a318-72cb7f82de66/live.isml/.mpd --test --allow-u
It downloads 2 files
.mpd [.mpd].faudio_track_0_0_dut=128000.m4a
.mpd [.mpd].fvideo_track=5000000.mp4
Is it correct? Now I need to install Python and try it.
Thank you all for you help
If you're Flemish, start with VTMGo and work your way up to VRT.
VRT Max is a harder one, as it needs a payload. Get a good grasp on understanding how everything works on a "normal" license request (VTMGo uses DRMToday) and then look in the scripts section of the GetWVKeys Discord. There should be a script there for VRT.
Hi to all !
I don't know why but when i try to open "keysdb.net", my Malwarebytes program blocks him immediately ! Is it a malware, "keysdb" ? And with the CDRM-project link, no problem occurred...
[Attachment 78411 - Click to enlarge]Last edited by GilbertA83; 16th Apr 2024 at 05:57. Reason: There was a fault inside a word.
For this video I encounter difficulties, the link is this:
MPDCode:https://mediasetinfinity.mediaset.it/video/lisoladeifamosi/giovedi-18-aprile-puntata-4_F312532901000401
PSSHCode:https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1553368_18ee409fa06645/dashrcenc/hr_wv_mpl.mpd
KEYSCode:AAAAU3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADMIARIQSrdrqiGl+N1vPI2DSfzlFhoNYW1hem9udHZjcmltZSIIdGFtX3Rlc3QqAlNEMgA=
But mp4decrypt returns me an encrypted file, both audio and videoCode:4ab76baa21a5f8dd6f3c8d8349fce516:bb11fbc9745b5d310dc388859bd96dcd
I don't understand where I'm wrong...
Thanks white_snake, for me work this:
with Iomero's mpdCode:N_m3u8DL-RE -M format=mp4 --key 4ab76baa21a5f8dd6f3c8d8349fce516:bb11fbc9745b5d310dc388859bd96dcd "https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1555079_18ef386f78ff89/dashrcenc/hr_wv_mpl.mpd" --save-name "decrypted_1"
(the system is much faster.)
Thanks lomero, this worked perfectly, how did you get this MPD?
Code:https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1555079_18ef386f78ff89/dashrcenc/hr_wv_mpl.mpd
Update
I found the right one in the chrome console (network), but "mpd detector" gives me the wrong one.Last edited by ferra1; 19th Apr 2024 at 18:30.
Upon further inspection I noticed you got things mixed up: the original .mpd you posted is for a different episode (Lunedì 15 aprile - Puntata 3), that's why the key didn't work (although the need to use shaka-packager for some Mediaset videos is real, so you might want to keep that in mind for the future). Browser extensions like The Stream Detector remember the previously loaded playlist urls, so you probably opened that other episode first and the playlist url was logged. For the record: The Stream Detector shows the correct .mpd url of course.
This said, while you're at it, you might want to download the 1080p version with this command instead:
Code:N_m3u8DL-RE -M format=mkv --key 4ab76baa21a5f8dd6f3c8d8349fce516:bb11fbc9745b5d310dc388859bd96dcd "https://vod06.msf.cdn.mediaset.net/farmunica/2024/04/1555079_18ef386f78ff89/dashrcenc/hd_wv_mpl.mpd"
Hello, can somebody help me to get the keys for this:
Code:https://arlocallivechannelsdash.lcdn.clarotv.com.ar/Content/DASH_DASH_FK/Live/channel(T5_SATELITAL)/master.mpd?ip=45.162.230.58&exp=1771168909&hmac=c0704413624765a97a9be4ce93dfb3de06f73deb
My headers file:Code:PSSH: AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEAwgj9FHkQJ7NobF2ycxLw0= License URL: https://widevine-claroglobal-vod.clarovideo.net/v2/licenser/getlicense?user_id=90195626 unable to parse license - check protobufs
My L3 cdm isn't working I tryied with the headers and all the request body and still the PROTOBUFS error.Code:import requests headers = { 'Origin': 'https://www.clarovideo.com', 'Referer': 'https://www.clarovideo.com/', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36 Edg/123.0.0.0', } data = { 'token': '7c9a1139666b7a5893c1c5ca4ded84ea', 'device_id': '693e9af84d3dfcc71e640e005bdc5e2e', 'widevineBody':'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'} response = requests.post('https://widevine-claroglobal-vod.clarovideo.net/v2/licenser/getlicense?user_id=90195626', data=data, headers=headers )
Thanks in advance
cdrm-project.com errors
By euphonic in forum Video Streaming DownloadingReplies: 13Last Post: 27th Jul 2023, 06:30 -
getwvkeys works but cdrm-project does not?
By Secondhand in forum Video Streaming DownloadingReplies: 11Last Post: 29th Apr 2023, 02:06 -
Problems with cdrm-project.com
By corvo4791 in forum Video Streaming DownloadingReplies: 11Last Post: 27th Apr 2023, 17:53 -
CDRM-project & GetWVKeys always respond with 401 unauthorized
By jjj in forum Video Streaming DownloadingReplies: 4Last Post: 25th Apr 2023, 18:23 -
Help to use cdrm-project.com
By vidsrme in forum Video Streaming DownloadingReplies: 6Last Post: 26th Mar 2023, 06:11
