    Feb 2002
    Olympia, WA
    okay, I'm in the US and that's NTSC.
    OK, so if I'm capturing digital cable and I'm not plugged directly in (from digital cable box to capture card composite-in) is the image still interlaced?
    How can I tell? I've never seen interlacing lines when viewing the original (before encoding to mpeg) captures using huffyuv.
    Is deinterlacing a non-interlaced source killing my quality?
    May 2001
    If the output of your digital cable box normally goes to your TV, then yes, the video is interlaced.
    How can you tell? Load a capture into Bitrate Viewer and read the stream info in the box.
    Feb 2002
    Olympia, WA
    aw, thank you.
