  1. I have been using the chrome extensions "Live Stream Downloader" to download tiktok live streams but a couple of days ago it stopped working.
    The flv files that I get don't have the video codec implemented.
    I have seen elsewhere that maybe tiktok has changed something on their end, but I've tried this same method on a different computer & it worked fine so I don't know.
    Does anyone else have this problem or maybe have a solution?
  2. Hi. I haven't personally experienced it, but I remember having a similar problem with another platform, LinkedIn. I needed to use it, as I have bought cheap real LinkedIn followers and wanted to continue promoting the account and keep it active. In my case, clearing the cache and updating the extension helped solve the problem. Try that and see if it works for you too.
  3. With this tool, you can record live streaming tiktok, even on android: https://github.com/Michele0303/tiktok-live-recorder/
  4. I’ve run into issues like this before with other tools, and sometimes it’s as simple as clearing the cache or updating the extension. If that doesn’t fix it, it might be worth checking if there’s a newer version of the extension or looking for an alternative that’s still working.
    Also, if you’re into growing engagement on your TikTok or social media in general, tools like https://getlikes.com/ can help boost your content while you’re sorting out the tech side of things.
