Hi,
I read the thread on why you might get dropped frames when capturing. However, it did not mention why dropped frames are an issue, and from what I read on here, they are. But why? I always figured that if the video and audio are on the same track, they are on the same frame, right? So, if they are, you would also lose the audio, together with the video, thus not having any sync issues at the end.
As a matter of fact. I notice ZERO sync issues with as many as 12 frames dropped, on a 3h tape. And let me tell you, I am super sensitive to video/audio sync issues.
Thanks.
EDIT: I forgot to mention that most of the the dropped frames occur when the tape "transitions" from one recording to another. I am not sure how to call it, but you know what I mean. When one recording ends, then there is static, and then there is another recording following.
P.S. Just for fun I asked ChatGPT, "Are video and audio recorded separately on a vhs tape? And here is the answer:
On a VHS (Video Home System) tape, the video and audio are not recorded separately. Instead, they are recorded together on the same tape in an analog format. The VHS format combines both the video and audio signals onto a single magnetic tape.
When you play a VHS tape, the tape passes over a rotating video head and an audio head. The video head reads the video signal from the tape, which consists of a series of horizontal lines that form the moving images. The audio head reads the audio signal, which corresponds to the sound associated with the video.
During the recording process, the video and audio signals are captured simultaneously by the recording device, such as a VCR (Video Cassette Recorder). The signals are then encoded and recorded onto the VHS tape as a single composite signal.
When you play back the VHS tape, the video and audio signals are read from the tape together and sent to your television or audio system for decoding and playback. The television or VCR separates the video and audio signals and processes them accordingly to display the video and play the audio.
Results 1 to 27 of 27
Well the HiFi audio and video are recorded by two separate heads on the drum, so in that sense it's separate.
When a frame is dropped it causes the previous frame to be repeated, leading to a visible stutter when the file is played back -
Dropped and/or inserted frames (not the same thing, btw.) indicate there is a problem, unless the number is very, very low. (I would ignore anything below 10 drops/inserts per hour of capture.)
It may indicate the sychronization pulses of the incoming analog video signal are too wonky to digitize a frame properly, or there may be an issue on the PC side of things, while writing the data to the HDD (interfering background tasks for example). And, of course, they may indicate audio sync issues.
Audio and video are handled independently inside the VCR, although the VCR cannot affect sync because it simply has no means of doing so.Last edited by Skiller; 27th May 2023 at 17:38.
I am not going to argue with you if it is separate or not, because I am not an expert, and I can only go by what I read. However, I still don't see why a repeated frame would be an issue? Fine, you see a stutter for a split second (25th of a second, in my case, I guess) but who cares, if anyone even notices. Besides, if the dropped frame is repeated by the previous one, why would there be a sync issue?
And like I said, I have no sync issues after 25 dropped frames and 3h later. Explain that.
Thanks. -
Glad to hear that because my "OCD" (not official, ha ha) is making me re-capture tapes that have 1 or 2 dropped frames over the span of 3hours.
That could be the problem. From what I remember, I had ZERO dropped frames when using my Panasonic EX95V. Now I am using my Blaupunkt RTV936 and I have dropped frames. That sucks because the EX95V had tracking issues. So it seemed.It may indicate the sychronization pulses of the incoming analog video signal are too wonky to digitize a frame properly,
I did not change anything on my PC so I think it must be the RTV936 that is doing this!?or there may be an issue on the PC side of things, while writing the data to the HDD (interfering background tasks for example). And, of course, they may indicate audio sync issues.
Ok. Thanks.Audio and video are handled independently inside the VCR, although the VCR cannot affect sync because it simply has no means of doing so.Last edited by plehoediv; 27th May 2023 at 17:47.
Dropped frames don't cause a sync problems because a duplicate is inserted, thus sync is maintained
Unless the settings call for it, You can mess up the capture software setting to not insert frames in case they are missing, therfore there will be audio drift, For the OP's case I would say a combination of wrong capture software settings and lack of signal stabilization by a way of TBC.
Not only does it make sense, but I can literally see no sync issues.
. So, in other words: If a "stutter" doesn't bother you, or you don't even see it (the stutter), dropped frames are not an issue. Right?
See, originally, I thought they (dropped frames) would "shift" something around and cause an issue, somewhere, down the line, like the Butterfly effect. I mean, if something is dropped, something else has to give, right? But I guess that is not the case since the frame is simply "replaced".
BAM! Thanks. No need for me to re-capture 10 tapes again because here and there is a frame missing. -
I use Scenalyzer and from what I remember, I did not change any settings. The signal goes from my VCR (no TBC) to my Camcorder TRV820e with TBC and from there to my PC. But again, if I have no sync issues, I have no issues, other than dropped frames, which are not an issue.
Thanks.
P.S. I am glad this turns out to not be an issue because I wanted to get my good old Dell PowerEdge T620 Server going again, so I can, yet again, capture all tapes that had dropped frames. Turns out I screwed up the order of my 6 hard drives AND I have memory issues... glad I do not have to fix that because I have no idea how to setup RAID, ha ha. -
I though you are capturing analog signal and have sync issues, So you're just ingesting the converted signal to DV into computer, So what's your problem then?
That VCR explanation you were given is wrong, or at least it was dumbed down to a point it became wrong, Audio and video are two separate things before entering the VCR, when they are recorded on tape and when they are played back from tape, and when going in to TV on a separate cables and processed on different circuit boards, the only relationship between audio and video is just timing. On broadcast TV in the other hand it's a different strory but that is unrelated to VCR.Last edited by dellsam34; 28th May 2023 at 00:49.
If you use a DV Converter to digitize the analog signal, the "classic" definition of inserted/dropped frames does not apply, and you have little control of what happens during the Analog to DV conversion.I use Scenalyzer and from what I remember, I did not change any settings. The signal goes from my VCR (no TBC) to my Camcorder TRV820e with TBC and from there to my PC.
The digital signal captured may show dropped frames while the stream is transferred to the PC via SCLive, which may happen for reasons related to the DV converter and/or the PC. They are somehow different from the inserted/dropped frames inherent to the Analog to Digital conversion. A check with AVPS DV Analyzer on the captured DV file is useful to check potential issues. -
I am not sure if I have a problem, that's why I am here to find out. VCR to Camcorder to PC. Scenalyzer shows dropped frames. I have no sync issues. Those are the facts. Question: Do I need to be worried about the dropped frame for whatever reason???
Good to know.That VCR explanation you were given is wrong, or at least it was dumbed down to a point it became wrong, Audio and video are two separate things before entering the VCR, when they are recorded on tape and when they are played back from tape, and when going in to TV on a separate cables and processed on different circuit boards, the only relationship between audio and video is just timing. On broadcast TV in the other hand it's a different strory but that is unrelated to VCR. -
Just to be sure: The conversion happens in the Camcorder, right? Has to be, because the signal going to the PC is via Firewire and that is digital.
.The digital signal captured may show dropped frames while the stream is transferred to the PC via SCLive, which may happen for reasons related to the DV converter and/or the PC. They are somehow different from the inserted/dropped frames inherent to the Analog to Digital conversion
I don't get that. Can you please "dumb" it down a bit for me?
Ok, now you are throwing the word "issues" around, without really saying what makes what an issue!?A check with AVPS DV Analyzer on the captured DV file is useful to check potential issues.
Thanks. -
Yes, the Camcorder digitize the audio/video stream and compress it with DV codec. The digital signal is then transferred to the PC via firewire connection.Just to be sure: The conversion happens in the Camcorder, right? Has to be, because the signal going to the PC is via Firewire and that is digital.
Because what said above, SClive will check the incoming digital stream while creating the dv avi file on the PC. If something is not correct (time code, frames, packets, ...) it will report so.I don't get that. Can you please "dumb" it down a bit for me?
The digital stream is created in real time by the Camera reading the analog a/v inputs, and the transferred to the PC. It may happen that a problem arise in the player, in the Camera or in the PC, leading to dropped frames. The last concerns interfering CPU tasks, I/O activity, background processes, as already noted by Skiller.
When transferring a DV stream from tape to PC (or when converting an analog a/v to DV and then transferring it to PC) you look for dropped frames, frames with video error concealment and frame with DV timecode incoherency.Ok, now you are throwing the word "issues" around, without really saying what makes what an issue!?
Here an example of a report from DV Analizer on one of my transfer with SCLive:
Code:DV Analyzer v.1.4.0 by AudioVisual Preservation Solutions, Inc. http://www.avpreserve.com C:\Sony DCR-PC6E\DV01\scene'20020102 16.31.58.avi Frame Count: 11136 Frame count with video error concealment: 551 frames Total video error concealment: 172797 errors ( 172797 "A" errors) Frame count with DV timecode incoherency: 1 frames Absolute time DV timecode range Recorded date/time range Frame range 00:00:00.000 00:55:10:16 - 01:02:36:01 2002-01-02 16:31:58 - 2002-01-02 16:39:23 0 - 11135 Percent of frames with Error: 4.95% Percent of frames with Error (including Arbitrary bit inconsistency): 4.95% Percent of frames with Video Error Concealment: 4.95% Percent of frames with Timecode Incoherency: 0.01%
EDIT: The point I was trying to make is kind of like having a dent in your car. That dent is there, you can see it, it will make the car less valuable, but it will NOT drive any different than without the dent, so it does not matter for the purpose of driving. Same with the dropped frames. There are there, I know why there are there, but I still don't know if there really make a difference when working with the footage later. Because as of now, just looking at the footage, I see no difference.
Thanks. -
While inserted frames are there to compensate a hole and to keep a/v in synche, dropped frames are more critical, because a lot of them may cause aynsh a/v. That's why for analog capture of problematic tapes we recommend an external TBC. If you have < 5 frames not consecutive or in proximity of the same place there should be no issues. If more, check a/v synch at the end of the capture.
P.S. from a collector point of view, fom me having a dropped frame in a video is like having a comic book without a page (exaggeration); for your purposes, you can live with that
I understand. Luckily, I have no sync issues, but I am going to check what the default setting is on Scenalyzer. Inserting frames or not.
My TRV820E has TBC. I think it is "good enough" of a TBC for what I am doing. I also have a ES15 and EH55.That's why for analog capture of problematic tapes we recommend an external TBC.
Scenalyzer has this feature where you can press N on your keyboard, and it will go the the next "error/dropped frame". Whenever I do that, I notice that 90% of all dropped frames are in the middle of transitions. You know, when one "tape" ends and another one begins, and it makes the tape have all that "static" or "streaks"...If you have < 5 frames not consecutive or in proximity of the same place there should be no issues. If more, check a/v synch at the end of the capture.
LOL, I know what you mean. See, the problem is that I can start going down the rabbit hole deeper, and deeper, and deeper. It never ends. I have to be careful to not overdo it, because that is what I do. I actually got my PowerEdge T620 Server going again. Dual XEON E5-2697 V2, 64GB RAM and a 780Ti. 2 x SSD for OS and 4 x HDD for Data. I got a Firewire card in the mail the other day and I am going to install it today. Just to see if it is my old Laptop that is not able to capture fine, or if it is the VCR...P.S. from a collector point of view, fom me having a dropped frame in a video is like having a comic book without a page (exaggeration); for your purposes, you can live with that
Thanks bro! -
Generally we speak about (line)TBC for a TBC inside a VCR or a Camcorder, acting intra-frame and (frame)TBC for an external TBC acting inter-frame with higher buffering capabilities.My TRV820E has TBC. I think it is "good enough" of a TBC for what I am doing. I also have a ES15 and EH55.
ES15 and EH55 are somehow in the middle. Sometimes they are good enough to stabilize a bad signal, sometimes a (frame)TBC is really needed. If in use, disable the (line)TBC of the Camcorder.
Now Bwaak will arrive and ask for an exact technical definition better than what I wrote
That's normal, no problem at all.Whenever I do that, I notice that 90% of all dropped frames are in the middle of transitions. You know, when one "tape" ends and another one begins, and it makes the tape have all that "static" or "streaks"...
Just capture the tape with dropped frames twice: if they are at the same instant in time, stop. Otherwise merge the "good" segments (DV is a intraframe only compressor).See, the problem is that I can start going down the rabbit hole deeper, and deeper, and deeper. It never ends. -
In most cases DV is not a rabbit hole for the average user as long as you use type II with locked audio, It becomes a rabbit hole when you start nit picking, that's why a project like DV rescue came to life, but that's for serious archivists and mainly focuses on digital tapes, Analog tapes are better captured without involving a DV codec but that has it's own set of issues.
[QUOTE=lollo;2691622]
Copy that.Generally we speak about (line)TBC for a TBC inside a VCR or a Camcorder, acting intra-frame and (frame)TBC for an external TBC acting inter-frame with higher buffering capabilities.
See, this is what I mean by going down the rabbit hole, because the last time I used both (EH55 and Camcorder) the TBC on the CC was turned on! Now you are telling me it should've been turned off. Now I got to redo the whole thing again, ha ha.ES15 and EH55 are somehow in the middle. Sometimes they are good enough to stabilize a bad signal, sometimes a (frame)TBC is really needed. If in use, disable the (line)TBC of the Camcorder.
So what.Now Bwaak will arrive and ask for an exact technical definition better than what I wrote
I wish I would have known earlier how to check for errors in Scenalyzer, so I could've seen where the dropped frames were. That way I would've realize they are very very often in those transitions and thus ignored them!That's normal, no problem at all.
Thats the plan. When I see the dropped frame is at let's say 01:34:25, I cut the footage with Shutter Encoder right before the dropped frame and then start the tape right before that time and see if it drops again.Just capture the tape with dropped frames twice: if they are at the same instant in time, stop. Otherwise merge the "good" segments (DV is a intraframe only compressor).
Anyhow, from what I can tell, dropped frames are not an issue. At least not in my case and I should stop f-ing around and just get the whole thing done.
Thanks. -
[QUOTE=dellsam34;2691630] Everything with me is a rabbit hole. Unfortunately.
I don't even know that type II with locked audio is?
Again, I do that with everything.It becomes a rabbit hole when you start nit picking,
What is that? A website?that's why a project like DV rescue came to life, but that's for serious archivists and mainly focuses on digital tapes,
What do you mean? Like with a USB Video Grabber or Capture Card?Analog tapes are better captured without involving a DV codec but that has it's own set of issues.
Thanks. -
Analog should be captured at YUV 4:2:2 lossless, with one of the recommended capture cards.What do you mean? Like with a USB Video Grabber or Capture Card?
With the DV route, assuming the quality of the A/D conversion of the DV converter is equivalent to that of the capture card, you introduce a degradation because the DV compression (DV codec uses intraframe DCT, sensitive to VHS noise) and the chroma subsampling to 4:2:0 (PAL) or 4:1:1 (NTSC).
The difference in term of quality is minimal (but present). Search the forum for comparisons between analog lossless captures versus analog DV captures. Some example here:
https://forum.videohelp.com/threads/360804-DV-vs-lossless-capture-of-VHS
However, if a restoration is planned, a lossless capture is more appropriate and effective.
An overview here: https://docs.google.com/presentation/d/1JFYHaKMZWHd8LFOVWmGuxdLNgFOiSXcoSxCMB-TXCvA/edit#slide=id.pWhat is that? A website?that's why a project like DV rescue came to life, but that's for serious archivists and mainly focuses on digital tapes, -
They may have done errors, but the whole concept is sound:
https://github.com/mipops/dvrescue
https://mipops.github.io/dvrescue/ -
You are telling me now? LOL.
Copy that.With the DV route, assuming the quality of the A/D conversion of the DV converter is equivalent to that of the capture card, you introduce a degradation because the DV compression (DV codec uses intraframe DCT, sensitive to VHS noise) and the chroma subsampling to 4:2:0 (PAL) or 4:1:1 (NTSC).
Will take a look. Thanks.The difference in term of quality is minimal (but present). Search the forum for comparisons between analog lossless captures versus analog DV captures. Some example here:
I guess I am going to "attempt" a restauration down the road. Hopefully by then AI will do it for me...However, if a restoration is planned, a lossless capture is more appropriate and effective.
Will check it out...
Thanks.
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
{"code": 2048, "message": "Authentication failed"} when getting license
By warmachine in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2023, 16:34 -
How to change "m3u8" to "json" and "ts" to "js" extension
By wowza in forum User guidesReplies: 6Last Post: 4th Mar 2023, 15:36 -
"sony-just-dropped-a-free-online-video-editor"
By hydra3333 in forum Latest Video NewsReplies: 3Last Post: 23rd Feb 2023, 23:08 -
Is this what they call "dropped frames"?
By Rahneshin in forum Newbie / General discussionsReplies: 10Last Post: 20th May 2021, 03:56
