Hello, I have 7 seasons of a rare old TV show that can't be found anywhere else. I want to avoid a generation loss by converting the file. The uploader probably thought that it would be a good idea to do 700 episodes in 16x9 even though it was originally shot in 4x3. I wrote this script with the help of chat GPT and no matter what I do batch is complaining about a track#4, which I don't understand where that comes from. My script and the video files don't even have any mention of track #4.
Error
Here's my scriptA track with the ID 4 was requested but not found in the file. The corresponding option will be ignored.
I tried many things like --video-tracks all but it doesn't work. I'm at loss and would like to preserve those file.Code:@echo off if [%1]==[] goto:eof set "sourceFolder=%~dp1" set "outputFolder=%sourceFolder%\remuxed" if not exist "%outputFolder%" ( mkdir "%outputFolder%" ) :loop "C:\Program Files\MKVToolNix\mkvmerge.exe" -o "%outputFolder%\%~nx1" --aspect-ratio 4:3 --track-order 0:0,0:0 "%~1" shift if not [%1]==[] goto:loop :eof pause exit
Thanks to anyone who can help with this!
I'm dumb, it's always when you post it that you see you had it in big caps in your face that whole time.
0:4/3
Fixed it all! -
Here's the remuxed MediaInfo of the file.
It is showing the followingCode:General Format : Matroska Format version : Version 4 File size : 244 MiB Duration : 24 min 38 s Overall bit rate : 1 387 kb/s Encoded date : UTC 2023-05-27 01:19:18 Writing application : mkvmerge v71.1.0 ('Fortitude') 64-bit Writing library : libebml v1.4.4 + libmatroska v1.7.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 16 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 16 frames Codec ID : V_MPEG4/ISO/AVC Duration : 24 min 38 s Bit rate : 1 001 kb/s Width : 624 pixels Height : 352 pixels Display aspect ratio : 4:3 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.152 Stream size : 176 MiB (72%) Writing library : x264 core 148 r2638 7599210 Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No
The flag is being picked up correctly in VLC but Plex is ignoring it. Do you know any better way that would be compatible with Plex without engendering a generation loss and convert?Display aspect ratio : 4:3
Original display aspect ratio : 16:9 -
ffmpeg can set the h.264 sar flags with a remux. See sample_aspect_ratio:
https://ffmpeg.org/ffmpeg-bitstream-filters.html#h264_005fmetadata
Code:ffmpeg -i input.mp4 -c copy -bsf:v "h264_metadata=sample_aspect_ratio=3/4" output.mp4
You would probably want to do both. Some players will obey the codec's flag, some the container's flag, and some will ignore both of them.
Note that the sar flag I used in the example assumes the source is square pixel (SAR 1:1) with a 16:9 frame size. So the pixels need to squeezed horizontally to force a 4:3 display size.
Batch Script for mux mp4 to mkv using mkvmerge
By iKron in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2025, 16:18 -
Mkvmerge, batch to mkvmerge add multiple audio tracks
By SrBills in forum Newbie / General discussionsReplies: 5Last Post: 15th Mar 2024, 12:03 -
anyone know if the following python script work ?
By DRMdec in forum Video Streaming DownloadingReplies: 2Last Post: 21st Feb 2023, 20:02 -
MP_Pipeline does not work. PLEASE check my script.
By JeremyVN in forum RestorationReplies: 1Last Post: 28th Feb 2022, 01:42 -
Looking for Batch MP4 Normalization Script of existing script
By VideoFanatic in forum Video ConversionReplies: 6Last Post: 31st Jul 2021, 20:50
