What code should I use to load MPG file to Avisynth+ for QTGMC'ing?
DirectShowSource, MPEG2Source, MPEGSource did not work saying "There's no function named "SetMTMode".
Help?
SetMTMode(5, 2)
DirectShowSource("Betacam.mpg", atrack=1)
AssumeTFF()
QTGMC(preset="Placebo", EZKeepGrain=1.0, SourceMatch=3, Lossless=2, Sharpness=0.4, SLMode=1, threads=2)
for file
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Duration : 15 min 33 s
Bit rate mode : Variable
Bit rate : 12.6 Mb/s
Maximum bit rate : 15.0 Mb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.215
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 1.37 GiB (95%)
Writing library : TMPGEnc Video Mastering Works 5 Version. 5.0.6.38
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B/G
Matrix coefficients : BT.470 System B/G -
Comment out the first line by placing # at the beginning of the line.
Save and retry -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
Getting QTGMC to load?
By killerteengohan in forum RestorationReplies: 2Last Post: 25th Mar 2022, 19:00 -
how do i load an image sequence into avisynth+ and can i use QTGMC on it ?
By oduodui in forum EditingReplies: 3Last Post: 28th Oct 2019, 16:45 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 03:12 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 21:57
