I normaly place the subtitles at the bottom of the screen. This time I need to change the vertical position to "Top of screen" (see my red arrow in the attachment). However, the only choice that is operational is "Bottom of screen". The other two are grayed out.
See the screen caption attached.
Amazing! Yes, ProWo, that was the way to do it, by changing the "bottom offset, pixels" value. I first tried 480 but the line came up on the center of the screen, then I changed it to 950 and it was at the top. I still can play with it, like a little higher or a smaller font, but what is important is that what you suggested is the way to do it.
Thanks a lot!
Change vertical pozition hardcoded sub HELP!
By Mariox in forum SubtitleReplies: 13Last Post: 24th Feb 2023, 09:00 -
Change on-screen position of PGS (SUP) subtitles
By YankeeFan in forum SubtitleReplies: 6Last Post: 21st Mar 2022, 11:43 -
VLC buttons change position!
By ten in forum Software PlayingReplies: 0Last Post: 22nd Jun 2021, 12:40 -
Unable to change position down the video in adobe premire
By sarit1 in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2020, 06:24 -
SRT, change vertical margin but keep 1-line subtitles vertically centered
By abolibibelot in forum SubtitleReplies: 15Last Post: 20th Aug 2019, 21:11
