  1. Can anyone recommend a reasonably priced option for blank 100gb discs for 4k ISO backup? UK stock preferably.
    Aug 2004
    PA USA
    I'm not aware of any consumer 100GB BD's that support 4K at the consumer level. Verbatim has https://www.verbatim-europe.co.uk/en/prod/bd-r-xl-100gb-4x-wide-inkjet-printable-5-pac...el-case-43789/
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
    Aug 2006
    There are these as well but I don't know if Amazon has the best price: https://www.amazon.co.uk/Verbatim-98897-blank-Blu-Ray-discs/dp/B00POY826G/
    Burning the ISO to a 100 GB BD-XL disc is one thing but finding a compatible UHD Blu-ray player that plays them is another problem. See https://forum.videohelp.com/threads/388243-BluRay-Player-with-BDXL-Support
