I just noticed that the video files produced by GFE are in limited range, is it possible to make capture full?
Results 1 to 13 of 13
Yeah, correct Sharc, Mediainfo tells only "after the event" the specs from the "result" … the file.
what i under stand of it, is that as soon if HDMI in consumer products is in the chain, it's the limited range 16-235/255
working only with computer/pro video hardware it's full range 0-255, i'm still learning in this area, it's an important thing when making a setup, and doing post work.
Even the semi pro people have to be very alert with this. -
Unless you really know what you're doing I recommend sticking with limited range YUV. All commercial and streaming video uses limited range. Your computer and software should be set up to convert limited range YUV to full range RGB for display or filtering.
Good subject here ! But by "commercial" you mean consumer ? when you say the conputer should be set to convert limited to full range, this is "only" for playback, i guess.
Talking about a computer with a computer monitor with HDMI,DVI or DisplayPort, would mean it's a full range color setup for playback. (not a NUC (miniPC) connected to a flatscreen TV, which is a different story… i guess)
The devil is in the details…..
I guess there are only few capture cards or expensive ones that capture in full range color, it's the hardware that dictates the setting for full or limited range color..
correct me if i'm wrong. -
You're eyes can't see YUV video. It has to be converted to RGB for you to see it. That is where the conversion from limited range to full range takes place. Limited range YUV is converted to full range RGB. By commercial video I mean Blu-ray disc, DVD disc, broadcast TV, broadcast satellite, Netflix and all the other streaming services, youtube, vimeo, etc.
I see. I assumed because I play in full range I should record that way too.
But if the final destination ie. Youtube, is limited range than I should do the initial recording in limited too?
I still don't know why GFE records in bt.601 though when from my searches hd content should use bt.709.
So I think I will stick to OBS where I can set bt.709.
color space bt709 to bt2020, but the player display color is different
By KaGaWu in forum Newbie / General discussionsReplies: 5Last Post: 14th Feb 2023, 04:43 -
Could you make a display with 4 subpixels and 4-primary color space?
By Qbcd in forum Off topicReplies: 0Last Post: 30th Jan 2022, 02:02 -
[HELP] Correct color space
By darkslayer00 in forum DVD RippingReplies: 1Last Post: 29th Nov 2021, 03:59 -
Color Space in x264 Via FFMPEG in CLI
By koberulz in forum Newbie / General discussionsReplies: 15Last Post: 11th May 2020, 13:48 -
Color space conversion quality loss
By tangled in forum Video ConversionReplies: 6Last Post: 26th Nov 2019, 07:47
