I have two MKV files, I want to copy the video from file1 plus the audio from file2 plus the subtitles of file2 to file3.
So:
File 1: Video
File 2: Audio, Sutbitles
= File3
Since this is 500 files, I want to do it with the command line, so I have:
mkvmerge.exe --output "file3.mkv" --no-audio --no-subtitles "file1.mkv" --no-video "file2.mkv"
The problem is that the first subtitle is enabled. I want to copy all subs, but disable them by default. Additional, the other problem is that not all subs have the same track ID.
Is it possible? I rather use mkvmerge, but I am also open to ffmpeg. It is important that there is no re-enconding.
Thanks!
Results 1 to 1 of 1
Imgburn Command Line
By sambat in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2020, 16:04 -
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 12:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 13:42 -
How to extract dvb subtitles from ts files using Subtitle Edit Command Line
By MounaLafi in forum SubtitleReplies: 0Last Post: 21st Jun 2019, 17:52 -
mkvmerge command line
By barbosa in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2019, 08:09
