  1. Rename a multiple of images within folders, each folder contains a multiple of images,
    each folder with a specific number, using text files, each text file with a folder number
    before
    Multi Folder Images
    ├── E01
    ├── E02
    ├── E03
    Multi Folder text
    ├── E01.txt   "inside text"
    │   ├── 0_00_01_713__0_00_05_081_01
    │   ├── 0_00_05_093__0_00_08_916_02
    │   ├── 0_00_08_926__0_00_12_339_03
    │   ├── 0_00_12_347__0_00_14_156_04
    │   └── 0_00_14_164__0_00_16_314_05
    ├── E02.txt
    │   ├── 0_00_16_324__0_00_17_348_06
    │   ├── 0_00_17_352__0_00_21_255_07
    │   ├── 0_00_21_260__0_00_23_501_08
    │   ├── 0_00_23_507__0_00_25_999_09
    │   └── 0_00_26_010__0_00_29_002_10
    ├── E03.txt
    │   ├── 0_00_29_013__0_00_32_176_11
    │   ├── 0_00_32_182__0_00_35_982_12
    │   ├── 0_00_35_993__0_00_37_245_13
    │   ├── 0_00_37_253__0_00_40_177_14
    │   └── 0_00_40_190__0_00_43_717_15
    after renaming
    Multi Folder Images
    ├── E01
    ├── E02
    ├── E03
    after & before renaming
    https://app.box.com/s/da31306nr4hizwgezi47kn6bv941i1f5
    I have this script Works on one folder . Please help to edit script
    import pathlib
    IMG_DIR = pathlib.Path('.\Images\E01')
    with open('E01.txt') as jabber:
        content = jabber.read().splitlines()
        director = sorted(IMG_DIR.iterdir())
        for src, dest in zip(director, content):
            src.rename(IMG_DIR / f'{dest}{src.suffix}')
  2. assuming txt files are all in that root directory, like in your example Image directory
    import pathlib
    ROOT_DIR =  pathlib.Path(r'F:\... path to root directory ...\Images')
    def rename_directory_files(directory, text_file, print_only=False):
        test it with print_only=True before actual renaming, if getting good results, proceed with renaming
        with open(text_file) as f:
            new_names = f.read().splitlines()
        files = sorted([file for file in directory.iterdir() if file.is_file()])
        for file, new_name in zip(files, new_names):
            if new_name and file:
                if print_only:
                    print(file, file.parent / f'{new_name}{file.suffix}')
                else:
                    file.rename(file.parent / f'{new_name}{file.suffix}')
    directories = [d for d in ROOT_DIR.iterdir() if d.is_dir()]
    for directory in directories:
                         directory = directory,
                         text_file = ROOT_DIR / f'{directory.name}.txt',
                         print_only = True
  3. Thank you. It works
