  1. i've tried all sorts of programs in windows and someone i just talked to is having the same problems in linux. the capture programs never seem to capture the picture, instead just show a blue or black background. one program i used in windows made a weird ghost image that made me think it worked, but when i tried to scroll the window down, the image seemed to be in a different layer and scrolled right out of the screen. does anyone know of a program that will capture mpeg2 stills?
    press p in windvd. and it should be possible with the http://www.hyperionics.com/hsdx/index.html if you configure correct.
  3. thanks baldrick. i was using an old version of windvd and never even knew about that.
  4. Guest
    i have the same problem only i use powerdvd. the camera on ati's mmc program is greyed out (in the media player... the tv will take pix). thats so odd
