Results 1 to 9 of 9
    May 2023
    Indonesia
    Who can help me to join discord getwvkeys?
  2. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    They're not allowing new members atm. Just use CDRM-project ?
  3. Why don't you use CDRM-project? If it does not work, you can always use TPD-Keys on your local machine to obtain keys that CDRM-project unable to.
    Apr 2023
    Europe
    Do you know when getwvkeys will accept new members please?? Thank you.
  5. Don't bother with them, you can learn it all from this forum, don't give them access to your Discord.
  6. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Why do you need GetWVKeys specifically for? You can do all of that with WKS as well
    Apr 2023
    Europe
    Thank you very much, sorry I am a newbie in this although I would like to learn a lot, I would like to get the Movistar keys and I thought that in GetWVKeys is where you could get them.... As I said I'm a newbie and I don't know where to look....
  8. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    CDRM does the same thing and does not require authentication or an invite, as long as the license server doesn't require a payload.
    Even if you somehow got an invite to the GetWVKeys Discord server, you'd still need either a readymade script or the knowledge on how to get the needed data to get the keys.
    I suggest you read around on this forum, there is a TON of information to ingest here and I'm sure 99% of your questions have already been answered before.
    Some basic things you need to learn:
    Find PSSH/MPD URL/License URL for the videos you're trying to download. This is the most important part, as without it you have nothing. Find out how to locate these things and then you can check if CDRM-project supports the license server without a payload (you can find this in the developer console, look at the requests being made to the license server). When you found this, you can fetch the keys for the video and learn how to download/decrypt/merge the files so you can actually use them.
    Apr 2023
    Europe
    Thank you very much, but please once I have the key what can I do to play it in Tivimate with a notepad in m3u? I have been told that I have to convert it from hex to base64, is there any application or page where I can do it? Thank you.
