https://www.gohitv.com/series/vi-vn/dr.-romantic-s03/1
is there any way to download subtitles from this site, really appreciate someone can help me
There is a subtitle file (but I'm not sure it will be much help) https://s.gohitv.com/subtitle/6a212c9556eb46058969859364166f901683344969321.xml
If you decode https://www.base64decode.org/ and then format thisat https://jsonformatter.org/xml-formatter it appears to have the timings and subtitles but the actual subtitle is encoded as base64? Not a full answer to your problem but a start.Code:<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <sub format="1"> <note height="1080" width="1920"/> <dia> <st>0:00:00.15</st> <et>0:00:02.11</et> <con>G6/LUhl9njKlA1ztXRgMK0BxVLyjb294I3uRfEoVCS19dFuLLOBk4F8JJDz/HQQBtmRQGQBDk2BHg4w+7+tjW5oWWguc2g62No70R8wFabGwumIY8x2HZ5drfaRpZUh7A05wyDHpc5kzYsW4DvMKsg==</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:00:34.18</st> <et>0:00:38.65</et> <con>VJC7QY3jLpFfekiVMLX/Ia4dQs/tIL8rr8M04yfwt0vt+KdPo3ZnrRm3ftgVe73npbOFJq0YOJLY7UCFeDsq+kUQmuC9OtrD5NysEB+v2ejBOOFFCGrunTppqBEyjVO7hZQuAWrnGALiNOWYD5D3VA==</con> <style> <font name="Tahoma" size="65" bold="0" italic="0" underline="0" strikeout="0" spacing="1.5" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="8" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:04.11</st> <et>0:01:05.35</et> <con>4q8iYYi+HrCVY8EuyVcsGMV5xqzYgMqNIIm/PuhW6Zw=</con> <style> <font name="Tahoma" size="65" bold="0" italic="0" underline="0" strikeout="0" spacing="1.5" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="8" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:05.45</st> <et>0:01:06.45</et> <con>Eq0eSVhix1+P/cNKTYz/6LRnE3o5uBBTELZMtpgXi98=</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:06.68</st> <et>0:01:08.48</et> <con>LPFGNK/1t2gAAwOPivSSmBBHUGEnS0sNNjatfZ0jFb8PkitX4uR3Sj3IJwrNiIYFlPmMQKxXLY+cFWtZQVXC1Q==</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:09.48</st> <et>0:01:10.65</et> <con>OcvAcrseZpTIhn7fSVB/zI9kAmrNA47MTwxAu4xkJik=</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:10.75</st> <et>0:01:12.01</et> <con>uAP1M6xeatyP6BNR96bysBYSHjP2Ck50osXpbMBLnn0NnoDwMtd2DaHgXX1TFnAv</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:12.11</st> <et>0:01:13.81</et> <con>DxLv8yIYcqqeastWhx1gikO3TGXgS/VOcrCIBV755KDVLlS6k5sFcIZOnkDUpY72</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:13.91</st> <et>0:01:15.85</et> <con>COG2ZDt8EBELP5xSUnRNgQZ9V9G6cd0d6gQ0V+TD7AMD2MGzkdaCexevBkK6FxV3</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:15.95</st> <et>0:01:17.65</et> <con>N7XSQUMsspE9yH9NFQPQw6G3UTFvBjZLCiMNg/dBK3j36mf+n0laJAimkMT16dfX</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:18.15</st> <et>0:01:20.35</et> <con>k6DltozndS8BWCzTl9GVljOrb+wfXQbTsZzpwQH/SMi4KY6o5sGzXbci4EoGIv4N</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:22.08</st> <et>0:01:23.88</et> <con>GaGoNeYdHOJ7cYc8RRQaBaodkZiA5tl40+uNv5DXKo4=</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia> <dia> <st>0:01:23.95</st> <et>0:01:25.58</et> <con>QFZ9ZcoXiPTwtgOWu6r/NHYPU6Igao/E7zus7UUL+KfRIN5tUDFsK7D+ppaIYOzLJSbMsudtbSfzVP0J/GCJUA==</con> <style> <font name="Arial" size="75" bold="0" italic="0" underline="0" strikeout="0" spacing="1.2" angle="0"/> <color primary="&H00FFFFFF" secondary="&H00000000" outline="&H97000000" back="&H00F3F3F6"/> <scale x="100" y="100"/> <border style="3" outline="1.99999" shadow="0"/> <position type="1" alignment="2" ml="30" mr="30" mv="101"/> </style> </dia>...... + loads more
is there no way to convert to regular srt? i can't decode this xml file, can anyone help me?
How to download from this site?
By Chapy in forum Video Streaming DownloadingReplies: 1Last Post: 18th Dec 2022, 23:23 -
How to download subtitles from this site??? Please help me 🥺...
By Lefi in forum Video Streaming DownloadingReplies: 11Last Post: 17th Jul 2022, 11:04 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 22:28 -
Please help download subtitles from this site. Overlay on Youtube video.
By MishaPrada in forum Video Streaming DownloadingReplies: 43Last Post: 26th Oct 2019, 17:29 -
How To Download the subtitles from this site?
By JohanCarlo in forum SubtitleReplies: 0Last Post: 27th Jul 2018, 18:28
