Hard to express this correctly.
I have a completed a word- accurate subtitle I made from VOSK and Subtitle Edit plus a copy of the public domain play.
Within that there is an extended space of songs in French and Italian-- an audition scene. Are there versions of the audio to text models in foreign languages? What I would do is simply snip and copy the French and Italian and then put it into my sub which is
completed in all other ways. (These are Baroque songs not even easily located from a few phrases in a Google search.)
The technique worked with Whisper where I needed a brief song lyric in English. That one actually could be understood by Whisper's small model, at least well enough to get it into text manually. That same video has a song at the outset that Whisper just displayed as [Music] in the usual way. But a friend was able to identify the source poem.
Results 1 to 13 of 13
This might be what you need. https://translatesubtitles.co/
Adobe Premiere has a text to speech feature that works in multiple languages. You can just pay for a month of use and there is a free introductory period.
Kdenlive is a free open source clone of Premiere and also has text to speech in multiple languages. But I never got it to work for me. It needs additional programs to work with and I can't figure out why they won't cooperate.
OOPS: I meant to say speech to text above. They will create text subtitles from the speech for different languages. You have to install a language pack for each language you want to subtitle.Last edited by ChasVideo; 22nd May 2023 at 11:59. Reason: I said text to speech and I meant to say speech to text
Thanks for answering. I Just began thinking about this after giving up for a while. The reason I gave up was I got no response from an expert forum on Baroque music-- not a word back -- and showed them where to find a clip. The video-- while not new- has been removed so a new direction is needed.
I don't know right now if a Whisper can just get the phonemes of the language to get some text. I will come back if I find I can get a sample.
My goal is to use all free tools for this , tools to get others involved in doing subs. -
In Subtitle Edit > audio to text option I see a whole list to select language other than English but with just the one available small model. I have no idea if French and Italian can run under the model. Something else to try. I have a clip made of the songs section.
No luck with Subtitle Edit on getting phonetic French or Italian. Whisper will identify [Italian Language] in brackets but
no response to the actual audio is given in either English or Italian in my clip. That's as far as I went with it. -
I sent this up and it looked completed but not posted so far.
I will put it on some cloud space for download or demux the audio and repost here. -
https://www.mediafire.com/file/7fptyt8gdu8f2rx/the_critic_songs_clip.mkv/file
there it is on mediafire.Last edited by loninappleton; 23rd May 2023 at 01:06.
Let me say I had the best luck with the Python Whisper version, OpenAI. The CPP would not work for me, CPU too old,
no AVX2 instructions, CPP crashes. The SSE version is just too slow.
Installed Python, and OpenAI, seems better.
But even still this is going to be very difficult. Took a small moment from your clip where they sing in French, produced French subs,
then translated to English @ https://translatesubtitles.co
https://www.mediafire.com/file/k30b8zmn8nqmx2m/critic_songs_clip.zip/file -
With my low level hardware and not knowing how to set up Python etc. I would say thanks for the effort but I could not pursue it
on my own. Perhaps in the future there will be other tools-- but really all I'd need is someone who knew Baroque music. These had to be popular songs and such of the period. But no references in the credits save for " music by Purcell Handel, Arne and Giordani" It's just not there. There's a long rendition of Rule Britannia (Matthew Arne) , Britons Strike Home and quite a selection of the Baroque style. The Play is a hoot. It's on Youtube.
I did try to follow the link to mediafire-- will try that again. Appreciate your taking the time with it. It was a long-shot with so little to go on. -
The new clip is downloading now from using the link here rather then the one presented by my email
change text color in Subtitle Edit
By loninappleton in forum SubtitleReplies: 20Last Post: 4th Nov 2022, 16:50 -
Subtitle translation, show lines as done (aegisub)
By UserName351 in forum SubtitleReplies: 0Last Post: 29th Dec 2021, 14:50 -
state of the art: automatic subtitle translation
By wandmaler in forum SubtitleReplies: 3Last Post: 30th Oct 2020, 04:45 -
Subtitle Edit: How to see original sub for translation but not its timings
By AmirATM in forum SubtitleReplies: 0Last Post: 20th Mar 2019, 03:58 -
how do I transition only the text or subtitle of the scene
By grNadpa in forum Newbie / General discussionsReplies: 6Last Post: 3rd Jan 2019, 12:19
