Hi, I have been trying to grab the subtitles from a free-to-stream series on Bravo TV, Top Chef Last Chance Kitchen so I can machine translate them to another language.
An example from Episode 1 of the latest season: https://www.bravotv.com/last-chance-kitchen/season-20/videos/when-titans-fall
There are subtitles visible on the stream, and I have tried several options to grab the subtitles, such as Stream Detector (on Firefox) and youtube-dlp and ffmpeg. None of them have been able to rip the subtitles though. I suspect the subtitles might be fetched from a script, but that is where my Google-fu fails me. When I inspect the site during a stream, there is a file that is fetched (polyfills.webvtt.js), leading to my suspicion.
Anyone has any tips to successfully getting the subtitle files from this stream? Would greatly appreciate it!
In case it's relevant: Windows 11, Firefox 113.0.1, latest youtube-dlp and ffmpeg (2023-05-18-git-01d9a84ef5 git essentials from https://www.gyan.dev/ffmpeg/builds/)
There's an EIA-608 stream muxed into the video. Download the video with yt-dlp and then run CCExtractor on it:
Code:"C:\Program Files (x86)\CCExtractor\ccextractorwinfull.exe" -autoprogram -trim --norollup "index_1-[index_1].mp4" CCExtractor 0.93, Carlos Fernandez Sanz, Volker Quetschke. Teletext portions taken from Petr Kutalek's telxcc -------------------------------------------------------------------------- Input: index_1-[index_1].mp4 [Extract: 1] [Stream mode: Autodetect] [Program : Auto ] [Hauppage mode: No] [Use MythTV code: Auto] [Timing mode: Auto] [Debug: No] [Buffer input: Yes] [Use pic_order_cnt_lsb for H.264: No] [Print CC decoder traces: No] [Target format: .srt] [Encoding: UTF-8] [Delay: 0] [Trim lines: Yes] [Add font color data: Yes] [Add font typesetting: Yes] [Convert case: No][Filter profanity: No] [Video-edit join: No] [Extraction start time: not set (from start)] [Extraction end time: not set (to end)] [Live stream: No] [Clock frequency: 90000] [Teletext page: Autodetect] [Start credits text: None] [Quantisation-mode: CCExtractor's internal function] ----------------------------------------------------------------- Opening file: index_1-[index_1].mp4 Detected MP4 box with name: ftyp Detected MP4 box with name: moov File seems to be a MP4 Analyzing data with GPAC (MP4 library) Opening 'index_1-[index_1].mp4': ok Track 1, type=vide subtype=avc1 Track 2, type=soun subtype=MPEG MP4: found 2 tracks: 1 avc and 0 cc Processing track 1, type=vide subtype=avc1 Changed fps using NAL to: 23.976000 Processing track 2, type=soun subtype=MPEG Closing media: ok Found 1 AVC track(s). Found no dedicated CC track(s). Total frames time: 00:13:10:874 (18962 frames at 23.98fps) Min PTS: 00:00:00:083 Max PTS: 00:13:11:081 Length: 00:13:10:998 Done, processing time = 1 seconds Issues? Open a ticket here https://github.com/CCExtractor/ccextractor/issues
Note: the latest released version of CCExtractor, 0.94, is useless (in my and others' experiences). 0.93 from the GitHub Releases page works well.
Supposedly, ffmpeg can extract the subtitles of the same, but I'm not familiar with the syntax or how good its support is. mpv shows the EIA subtitles directly too - I guess thanks to ffmpeg. -
Massive thank you, AbortRetryFail!
CCExtractor 9.3 did the trick. Turns out the generated files from ffmpeg and yt-dlp both had the embedded subtitles, they were just not showing up when playing in MPC-HC. I also tried downloading using VDH's HLS as M2TS option, and the generated M2TS had the subtitles embedded too.
I had not even heard of EIA-608 stream until today. How does one find out whether the subtitles are encoded in an EIA-608 stream?! (I am clearly a newbie to all this)
I had a site that I absolutely couldn't find the subs for. The company providing the streaming infrastructure has a page with their open source projects and one of them happened to be an EIA decoder implemented in JavaScript. The penny dropped. That site is harder than most, so many months later after managing to get a key with a standard L3, I was able to confirm my suspicions. After that, I make it something to check for. (CBC Gem also delivers subtitles like that.)
Code:Text ID : 1-CC1 Format : EIA-608 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 13 min 10 s Start time (commands) : 5124095 h Start time : 5124095 h Bit rate mode : Constant Stream size : 0.00 Byte (0%) Count of frames before first event : 19 Type of the first event : PopOn
Online? I have no idea. You can check for the presence of the usual subtitle delivery methods (straight-up request for a TTML or WebVTT file, subtitle DASH stream defined in the MPD and something else I'm missing?) and assume EIA is a possibility in the absence of them. EIA subtitles won't directly show up in your browser's requests like that. In my basic understanding, EIA subtitles are signals attached to the video feed (look at the image in the Wikipedia page) and on top of that, the video might be encrypted, so you'll never see a nice text representation in the requests.
And if you're not dealing with a site that sticks to defined standards, like a site streaming content they are not licensed for, they might roll out their own bespoke obfuscation/encryption to stop other sites from stealing their translations or whatever...
Help to download subtitles
By farafero21 in forum Video Streaming DownloadingReplies: 5Last Post: 13th Jul 2022, 02:41 -
Bravo DL
By monsterbubble in forum Video Streaming DownloadingReplies: 3Last Post: 29th Apr 2022, 17:31 -
How do I download subtitles from Netu TV?
By lekic.nx in forum SubtitleReplies: 2Last Post: 21st Jan 2022, 14:40 -
Help: How To download Encrypted videos from Jwplayer
By hamada_mohamed in forum Video Streaming DownloadingReplies: 5Last Post: 7th Oct 2021, 10:44 -
Jwplayer 8.14.0 hls Stream Download Method?
By Franseven in forum Video Streaming DownloadingReplies: 4Last Post: 15th Jan 2021, 09:18
