Easy Question for some of you I think, but I don't see it as a newbie question.
I have a 702x576 Huffyuv encoded vid, and I'd like to know if i should use VirtualDub to convert it to 384x288 in VirtualDub, and then make it a VCD in TMPGEnc, or if i should convert the 702x576 to VCD directly with TMPGEnc. Which one will be of better quality?
And also, what are recommendable filters to use with VirtualDub when converting to VCD.
~ILJR
The best way is to encode it with TMPGEnc as a vcd using the standard vcd template.
I don't like using filters, unless there is a problem with the picture quality otherwise it's not worth the trouble and could make the picture quality worse.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Conversion Help
By slayer_of_all in forum Newbie / General discussionsReplies: 2Last Post: 8th Apr 2010, 09:45 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
no sub after conversion
By volam in forum Video ConversionReplies: 0Last Post: 5th Sep 2008, 14:31 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 23:21
