Here's the thing.
Back in the days when we did not have a real SD to HD conversion, I converted some SD videos, originally from DVD resolution, to 720p or 1080p using Vidcoder.
The main advantage was manipulations of those videos, particularly for subtitles, because there was no "real resolution gain".
Now several programs have been released, supposedly IA controlled, like Topaz Video Enhance AI and some others that are even better, that analyze each frame and process the image in a very effective way.
I did process a whole documentary I had shot in DV and converted to mkv, and the results were magnificent. Contrary to the Vidcoder processing, where you could not find any differences between the SD and the fake-HD frames, this time you can see visible improvements.
Now my question: how do I do to go back from a "fake-HD" video onto its original format, so I can reprocess it with Topaz?
If there was quality loss when making HD "versions" of the SD files, it was not visible on a side by side, zoomed view of same SD and HD file
Some filters were used, like those mentioned, on the Vidcoder when I made the conversion to mkv, some to 720p.
As I intend to upscale to 1080p, not 4K, starting from 720p mkv would be fine. What I was thinking to do with the 1080p files was to turn off most of the filters in Vidcoder and descale them to 720p too.
I completely forgot how to process things with Avisynth, which I had refined very much in my DVD SD days.
If anyone knows Vidcoder, it would be great what settings would be recommended to use to go from 1080 to 720p just adjusting the size and nothing else.
DVD/BLU RAY Back-up --- Best Way to Watch Back on TV
By Ashthezombieasskicker in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2022, 20:34 -
The Beatles: Get Back
By taigi in forum RestorationReplies: 9Last Post: 26th Dec 2021, 21:11 -
Remove duplicates from pal conversion to get back to 23.976
By embis2003 in forum RestorationReplies: 14Last Post: 20th Aug 2021, 12:02 -
Converting PAL conversion back to NTSC
By Master Tape in forum RestorationReplies: 5Last Post: 6th Aug 2020, 03:16 -
A Look Back Into 720 vs 704
By dellsam34 in forum Capturing and VCRReplies: 12Last Post: 19th May 2020, 19:23
