I have a DVR-550H. HD works great and the DVD seems to burn without an issue. The only thing is the DVD is very finicky on what DVDs it will play. I see several posts on this units laser getting weak over time burning DVDs but mine does not seem to have this issue. I have taken apart the DVD and blew out the dust in the lens. Is my problem the laser pickup or is it just out of adjustment?
You should use a cleaning CD. Most of the times there is dust or a fine film on the laser lens that causes these problems. Buy a cleaning CD since CDs are the easiest to read-in vs. cleaning DVDs. Or - if you can access the laser lens - use a cotton swab with alcohol to clean it.
For writing the laser uses its full power. For reading something like 10% of it at that might be too less when the lens is polluted.Last edited by Moody_Blues; 16th May 2023 at 13:15.
I performed surgery on the DVR a couple years ago getting it to where I could access the laser. It was quite a lot of work to get to it. I did use a cotton swab and alcohol. I will have to pick up a CD cleaner.
I put a bit of alcohol on the little bristles of the CD lens cleaner using a cotton swab just before loading. Don't know if it actually helps, it something I do.
Does anybody have a recommendation of a cleaning CD? Maxell CD-340?
https://www.amazon.com/gp/aw/d/B000001OM5/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1 -
The CD lens cleaners are pretty much all the same, a CD with bristles. Any brand would do. Your link is at a good price.
Pioneer GGV 1305 Service Disc, Compatible with Pioneer DVR-560H?
By Big Al in forum DVD & Blu-ray RecordersReplies: 29Last Post: 1st Apr 2025, 07:51 -
Pioneer DVR-520 and DVR-560 functionality discussion
By jcool in forum DVD & Blu-ray RecordersReplies: 142Last Post: 17th Aug 2021, 20:45 -
DVR to PC - Pioneer DVR 550HX
By codylion in forum Newbie / General discussionsReplies: 8Last Post: 30th Jan 2021, 18:44 -
Pioneer DVR-LX61D.
By OldSchool297 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Jul 2020, 11:57 -
Pioneer DVR LX60D 8mm, Hi8 and VHS recording to DVD
By Loganix in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2019, 03:25
