  1. I have a couple hours of footage from two different cameras. JVC GZ-MG130u and Nikon Coolpix 3200. The JVC gives me 29.97 fps, and the Coolpix 15 fps.
    Mediainfo for both follows.
    JVC:
    G: MPEG-PS, 45.6 MiB, 39 s 552 ms, 9 662 kb/s
    V: MPEG Video, Main@Main, 720x480, 29.970 FPS, 9 086 kb/s
    A: AC-3, 384 kb/s, 2ch, 48.0 kHz
    M: Menu
    General
    Complete name                   : MOV07A.MOD
    Format                          : MPEG-PS
    File size                       : 45.6 MiB
    Duration                        : 39s 552ms
    Overall bit rate mode           : VBR
    Overall bit rate                : 9662 Kbps
    FileExtension_Invalid           : mpeg mpg m2p vob vro pss evo
    Video
    Format                          : MPEG Video
    Format version                  : Version 2
    Format profile                  : Main@Main
    Format settings                 : CustomMatrix / BVOP
    Format settings, BVOP           : Yes
    Format settings, Matrix         : Custom
    Format settings, GOP            : M=3, N=15
    Format settings, picture structure: Frame
    Duration                        : 39s 540ms
    Bit rate mode                   : VBR
    Bit rate                        : 9086 Kbps
    Maximum bit rate                : 8900 Kbps
    Width                           : 720 pixel
    Height                          : 480 pixel
    Display aspect ratio            : 4:3
    Frame rate                      : 29.970 (30000/1001) fps
    Standard                        : NTSC
    Color space                     : YUV
    Chroma subsampling              : 4:2:0
    Bit depth                       : 8 bit
    Scan type                       : Interlaced
    Scan order                      : TFF
    Compression mode                : Lossy
    Bits/(Pixel*Frame)              : 0.877
    Time code of first frame        : 00:00:00:00
    Time code source                : Group of pictures header
    GOP, Open/Closed                : Closed
    Stream size                     : 42.8 MiB (94%)
    Color primaries                 : BT.601 NTSC
    Transfer characteristics        : BT.601
    Matrix coefficients             : BT.601
    Audio
    ID                              : 189 (0xBD)-128 (0x80)
    Format                          : AC-3
    Format/Info                     : Audio Coding 3
    Commercial name                 : Dolby Digital
    Muxing mode                     : DVD-Video
    Bit rate mode                   : CBR
    Bit rate                        : 384 Kbps
    Channel(s)                      : 2 channel
    Channel layout                  : L R
    Sampling rate                   : 48.0 KHz
    Frame rate                      : 31.250 fps (1536 SPF)
    Stream size                     : 1.81 MiB (4%)
    Service kind                    : Complete Main
    Coolpix:
    G: QuickTime, 10.3 MiB, 20 s 800 ms, 4 145 kb/s
    V: JPEG, 640x480, 15 FPS, 4 060 kb/s
    A: English, PCM, 64.0 kb/s, 1 channel, 7 875 Hz
    General
    Complete name                   : DSCN3598.MOV
    Format                          : QuickTime
    Format/Info                     : Original Apple specifications
    File size                       : 10.3 MiB
    Duration                        : 20s 800ms
    Overall bit rate                : 4145 Kbps
    Movie_More                      : NIKON DIGITAL CAMERA
    Encoded date                    : UTC 2021-05-04 19:46:24
    Tagged date                     : UTC 2021-05-04 19:46:24
    Writing library                 : Nikon
    Origin                          : Digital Camera
    Video
    Format                          : JPEG
    Codec ID                        : jpeg
    Bit rate mode                   : VBR
    Bit rate                        : 4060 Kbps
    Width                           : 640 pixel
    Height                          : 480 pixel
    Frame rate mode                 : CFR
    Frame rate                      : 15.000 fps
    Color space                     : YUV
    Chroma subsampling              : 4:2:2
    Bit depth                       : 8 bit
    Bits/(Pixel*Frame)              : 0.881
    Stream size                     : 10.1 MiB (98%)
    Language                        : English
    Audio
    Format                          : PCM
    Format settings                 : Little / Unsigned
    Codec ID                        : raw
    Bit rate mode                   : CBR
    Bit rate                        : 64.0 Kbps
    Channel(s)                      : 1 channel
    Sampling rate                   : 7875 Hz
    Bit depth                       : 8 bit
    Stream size                     : 160 KiB (2%)
    Language                        : English
    If I want, say, JVC footage as a background with an inset of Coolpix footage, would my only options be to find a way to effectively double the 15fps footage (which I'm sure would be absolutely jarring, unless someone knows some QTGMC script I don't) or reducing the framerate of the JVC?
    I'm guessing there's no way to let the footage coexist, within the same frame, in its native form?
    I'm using Shotcut for my NLE. I refuse to adopt the Adobe model of monthly payments, and I prefer open source software anyway.
  2. You can try motion interpolation of 15fps to 29.97fps using RIFE or mvtools2 or similar - basically "optical flow" methods . They synthesize "inbetween" frames , and can sometimes look ok, but other times can produce distracting artifacts. It depends on the source content
  3. Banned
    Nov 2022
    Shooting at 15 fps in 2021? Your MOD file is 30i, so you need to quadruple Coolpix's frame rate if you want frame rates to match, not just to double.
    Originally Posted by archiveresearch View Post
    would my only options be to find a way to effectively double the 15fps footage (which I'm sure would be absolutely jarring, unless someone knows some QTGMC script I don't)...
    QTGMC is a deinterlacer. Why would you want to deinterlace 15p footage?
    ...or reducing the framerate of the JVC?
    You can reduce 30i to 30p or 15p, or increase 15p to 30p or 30i or 60p, whichever.
    Why would not you try instead of guessing? You don't need to change frame rate simply to have an inset, your NLE will adjust frame rate for you. There may be settings, like either simply duplicate frames or interpolate them.
  4. Originally Posted by archiveresearch View Post
    The simplest way would be to use ChangeFPS(30000, 1001) on the 15 fps clip. That will double each frame (except every 1000th) and make a 29.97 video out of the 15 fps video. Then you Overlay() the (previously) slower clip onto the faster clip. Of course the slower clip will be jerky.
    slowclip = WhateverSource("15fpsclip.ext")
    fastclip = WhateverSource("29.97fpsclip.ext")
    slowclip = slowclip.ChangeFPS(30000, 1001) # or fastclip.framerate
    Overlay(fastclip, slowclip, x=?, y=?)
    # encode interlaced
    Or you could use AssumeFPS(30000, 1001) on the slower clip to make it run ~twice as fast. And Overlay. The slow clip will now be smoother but twice as fast.
    slowclip = slowclip.AssumeFPS(30000, 1001) # or fastclip.framerate, twice as fast, half as long
    # encode interlaced
    Or, as mentioned earlier, you can try using motion interpolation. That can work well for panning shots but may deliver distortions with complex motions.
    slowclip = slowclip.FrameRateConverter(NewNum=30000, NewDen=1001)
    # encode interlaced
