Does anyone here can help me find if this is a belt or a motor issue?
First of all, when I turn on the machine, it gets off and I see ---- on the screen.
When I insert the tape on when the unit is turned off, It turns on and play.
Over a week, tape is hard to insert. I need to push it kind of hard until the vcr turns on, but it's working.
Now it won't work unless I give it a little push on the motor's spindle with my finger.
Video is on youtube because I can't upload here
https://www.youtube.com/watch?v=PO80iWkDFfI
Results 1 to 10 of 10
Either the belt is loose or the motor is dying, You need to find out which one is causing the problem and replace it.
I removed the belt, powered it on and the motor spins.
When I insert a tape, it spins too !
So it might be a belt problem although it looks good, not dry and has tension? -
it spins freely but how about if you put a load on it by holding it, does it have enough torque?
Hi
Please see this video
When I turn on the machine, motor spins freely but when I put the belt on, it stops.
https://youtu.be/Prf1KaqiXa4 -
Replace the motor.
Perhaps 1 missing tooth on the gears related to the motor.
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Yes, 12voltvids at youtube has mentioned many times, a lot of VCR's,
The plastic/nylon gears can develop a crack and become ineffective.
In some cases he uses epoxy resin to fix -
I have replaced the dc motor from another used jvc machine and it works like a charm!
Glad you got it fixed, You saved another machine from the landfill.
JVC DR-MV1 loading problem
By fixit24 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Apr 2023, 10:09 -
JVC Camcorder GR 60 E problem with stuck mechanism
By 030303 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Aug 2022, 16:00 -
miniDV decks LOUD rewind noise from motor
By nicholasserra in forum RestorationReplies: 3Last Post: 6th Jul 2021, 03:32 -
JVC HR-J737MS any good?
By idan182 in forum Capturing and VCRReplies: 3Last Post: 1st Aug 2020, 02:00
