This is the weirdest thing...
Everything seemed to be going swimmingly. I had taken my original DVD of the film 'MOONTRAP' and using MakeMKV created an MKV file of the movie. Then playing around with Avisynth, I figured out how to denoise it a little using TemporalSoften or something like that. So, then using an x264 CMD line I rendered it using a few tweaks. The resulting file looked fine, BUT... when I went to mux it with the original audio from the same DVD MKV file, it ends up out of sync. It SEEMS to be in sync at the beginning, but gradually the audio begins to precede the video, so at the end of the 1:30 or so, there is about a 1 or 2 second lag in the video.
One think I DID notice was that strangely although the resulting MakeMKV rendered MKV file with MediInfo showed it to be at a 23.976 framerate, for some odd reason after encoding it with x264 the file read as 29.xxx I sure don't know where that came from. But if the audio is at the original frame rate and the video is now THAT far off, wouldn't the difference be FAR greater? Oddly, the running time shown on both files was 1:30. Very strange...
Then I remembered in the past (and also noticed the BDRB always includes this line in the encoding) that sometimes when the streams were out of sync I would include the AVS line 'AssumeFPS(24000,1001)' But, after reencoding it again with this command, it very oddly showed that it now had a running time of 1:53!?? WTF!? But, when playing it, the film actually ended at 1:30 and part of it for some weird reason started to repeat. So, I just ran it through MKVMerge and chopped off the extra. But, now that the video stream reads as 23.976, the audio is even farther off!
I can't for the life of me figure out WHY that is when both before and after files are the same length. And, I cannot figure out how the hell to get the A/V properly in sync. I TRIED playing around with the MKVMerge settings for 'stretch' and 'duration', but none of it made any sense.
I'm SURE that there must be some basic step I'm missing, but I sure cannot figure out what it is. Any help would be greatly appreciated!
Thank you!
	Ah, thank you all! Very good information and helpful.
 I will remember this for future tries. Actually, I was able to 'cheat' and import it into BDRB and then drop the AVS code into it. It did render it correctly, but I needed to learn these things, thanks!
  MKV file out of syncBy techmot in forum Video ConversionReplies: 6Last Post: 24th Dec 2022, 11:38
  AviSynth Script - Can't index VP9 MKVBy VideoFanatic in forum RestorationReplies: 25Last Post: 10th Dec 2021, 22:50
  DVD to MKV with ffmpeg + Avisynth, questions about audio and chaptersBy abolibibelot in forum Video ConversionReplies: 4Last Post: 9th Nov 2021, 08:14
  Ripbot rendered file not full-lengthBy frodawgg in forum Video ConversionReplies: 2Last Post: 16th Jul 2021, 12:25
  Handbrake or AVIsynth for encoding?By ryugu in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2019, 23:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
