Man, apparently I have a LOT to learn!
Okay, I took a very good looking HEVC HDR encoded MKV file of about 6 gigs and I wanted to convert it to a regular (1080) playable Blu-ray. I used BDRB which does the conversion, but WOW it looks totally different. When I play the original HEVC file with VLC, the colours are super deep and vibrant, it looks great! But... after converting it, it now looks all washed out and horrible! What the hell did I do? I'm GUESSING it has something to do with the HDR which I believe has to do with how the colours are processed. But man, what a HUGE difference! Is there any way to convert these kinds of lovely looking HEVC HDR files into a playable x264 Blu-ray format and be able to keep all that colour? Otherwise, there just is no point it looks so awful.
And, I can't just settle with playing them with the VLC player, because although I do have a fairly strong up to date computer, video card, memory, and my OS on an SSD, AND I've done a bunch or research online, it does not play smoothly. I did change some of the settings on the VLC player like disabling the hardware acceleration which did help. And I did the setting the FFMPEG threads and the x264 threads to '3' thing, and increased to a huge cach size AND tried changing the output video modules, but although better it still doesn't play right. Therefore my strong desire to convert it to a playable format for my old OPPO player like Blu-ray. BUT... only if I can keep all those beautiful colours!Is there a 'simple' way to do that, or should I only try to convert NON-HDR encoded HEVC files if I wish to do that?
Really appreciate any input or suggestions, thanks!
Results 1 to 9 of 9
I ran into this issue. You need to use BT709 colour space.
Jagabo, please do not reply to this post. Thank you. -
Thanks! I'm now reading about converting using Handbrake and I've come across several comments about using the BT709 colour space. But... I don't know how to use it
My first reading about Handbrake LOOKED like it did it automatically even converting from UHD HDR to 1080 Blu-ray, but some seem to say there is a colourspace setting somewhere.
Is there a setting in BDRB that does that conversion? That is what I used in converting it like I said above, but the resulting colours were not right. Is there either a CMD line for x264 which I am familiar with, or some simplified GUI I can use to do this, or can I just try Handbrake and will I need to see some kind of colourspace setting? Thank you! -
Yessir! I did find it
I did a preview, and let me tell you, it looked a HELL of a lot better than my encode did through BDRB! This is slightly along the same lines, but what I would LIKE to do when I use Handbrake to do this, I can't seem to see a way to set a predetermined output size. The reason being is that say I'm taking a 6 Gig MKV file and I have an HD audio track. So, to be able to play it on my old OPPO player, I would LIKE to be able to set the encoding so that it fills almost the whole Blu-ray to preserve as much quality as possible. I would leave room of course for the MKV to BDMV folder overhead and for remuxing in the HD audio track. But, other than just setting the 'Quality' (say CRF=16) and setting the preset to Fast, etc., or giving a specific bitrate, I don't see where I can set it simply to output say a 16 Gig MKV file. Is there a way to do that with Handbrake? If so, I believe I'm set!
2160p HEVC HDR Dolby Vision video on SDR 1440p display shows bad colors
By psycketom in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2021, 01:19 -
HDR hevc MKV to SDR mkv
By Hectarea in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2020, 21:19 -
Problems converting 4K HEVC HDR-10bit videos to 4K SDR H.264
By Emy78 in forum Video ConversionReplies: 8Last Post: 26th Nov 2020, 23:18 -
cut at keyframe HEVC 10bit HDR editor?
By lifespeed in forum EditingReplies: 1Last Post: 23rd Nov 2020, 15:26 -
Playing 4K HDR HEVC video on 2017 MacBook Pro to external monitor
By hmnlzr in forum MacReplies: 3Last Post: 20th Mar 2020, 15:52
