Hello,
I am new here and I hope I have got the correct forum.
If not, can the administrator please move the thread to the correct place.
I am calling FFMPEG V6.0 von Neumann from a MS VS .NET WPF C# process which seems to work pretty well.
But I cannot get the video filter smarblur to work. I always get the message:
[AVFilterGraph @ 000001d1a3e27580] No such filter: 'smartblur'
this is the output from the standard error file. it contains the ffmpeg command i used to invoke the program
and it contains all the output I get.
If I ommit the "smartblur" filter the process generates the desired single JPG image (but it is no sharp).
Has anybody an ideea what is wrong - Any help very wellcome
Wolfgang
================ error output ================================================== ==
DefImg 147: UpdateImage started
DefineImage 155 11.05.2023 09:23:51 C:\ffmpeg\bin\ffmpeg.exe -y -nostdin -f dshow -an -video_size 1280x960 -framerate 10 -i video="USB Microscope" -filter:v "smartblur=luma_radius=0.9:luma_strength=0.7:luma_ threshold=0" -frames:v 1 C:\FilmProjList\TEST\TEST%%04d.jpg -update 1
"Cine2Video.exe" (CoreCLR: clrhost): "C:\Program Files\dotnet\shared\Microsoft.NETCore.App\7.0.5\Sy stem.Runtime.Serialization.Formatters.dll" geladen. Das Laden von Symbolen wurde übersprungen. Das Modul ist optimiert, und die Debugoption "Nur eigenen Code" ist aktiviert.
DefineImage 180 ffmpeg version n6.0-18-g27205c0b47-20230508 Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 12.2.0 (crosstool-NG 1.25.0.152_89671bf)
configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-version3 --disable-debug --enable-shared --disable-static --disable-w32threads --enable-pthreads --enable-iconv --enable-libxml2 --enable-zlib --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-libvorbis --enable-opencl --disable-libpulse --enable-libvmaf --disable-libxcb --disable-xlib --enable-amf --enable-libaom --enable-libaribb24 --disable-avisynth --enable-chromaprint --enable-libdav1d --disable-libdavs2 --disable-libfdk-aac --enable-ffnvcodec --enable-cuda-llvm --disable-frei0r --enable-libgme --enable-libkvazaar --enable-libass --enable-libbluray --enable-libjxl --enable-libmp3lame --enable-libopus --enable-librist --enable-libssh --enable-libtheora --enable-libvpx --enable-libwebp --enable-lv2 --disable-libmfx --enable-libvpl --enable-openal --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopenmpt --enable-librav1e --disable-librubberband --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libsvtav1 --enable-libtwolame --enable-libuavs3d --disable-libdrm --disable-vaapi --disable-libvidstab --enable-vulkan --enable-libshaderc --disable-libplacebo --disable-libx264 --disable-libx265 --disable-libxavs2 --disable-libxvid --enable-libzimg --enable-libzvbi --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-ldexeflags= --extra-libs=-lgomp --extra-version=20230508
libavutil 58. 2.100 / 58. 2.100
libavcodec 60. 3.100 / 60. 3.100
libavformat 60. 3.100 / 60. 3.100
libavdevice 60. 1.100 / 60. 1.100
libavfilter 9. 3.100 / 9. 3.100
libswscale 7. 1.100 / 7. 1.100
libswresample 4. 10.100 / 4. 10.100
Trailing option(s) found in the command: may be ignored.
Input #0, dshow, from 'video=USB Microscope':
Duration: N/A, start: 62503.199898, bitrate: N/A
Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422(tv, bt470bg/bt709/unknown), 1280x960, 10 fps, 10 tbr, 10000k tbn
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> mjpeg (native))
[AVFilterGraph @ 00000157ee397580] No such filter: 'smartblur'
Error reinitializing filters!
Failed to inject frame into filter network: Filter not found
Error while processing the decoded data for stream #0:0
Conversion failed!
DefineImage 248 11.05.2023 09:23:54
DefineImage 155 11.05.2023 09:23:57 C:\ffmpeg\bin\ffmpeg.exe -y -nostdin -f dshow -an -video_size 1280x960 -framerate 10 -i video="USB Microscope" -filter:v "smartblur=luma_radius=0.9:luma_strength=0.7:luma_ threshold=0" -frames:v 1 C:\FilmProjList\TEST\TEST%%04d.jpg -update 1
Duration: N/A, start: 62509.541373, bitrate: N/A
Stream mapping:
Conversion failed!
DefineImage 248 11.05.2023 09:24:00
Das Programm "[8268] Cine2Video.exe" wurde mit Code 0 (0x0) beendet.
Obviously your ffmpeg do not support such filter - you can list all supported filters in your ffmpeg by using bellow command:
If there is no smartblur on the list then you are out of luck - try different build and/or verify dependencies necessary to build ffmpeg with smartblur active (perhaps it use non GPL license so it will be omitted by GPL ffmpeg build).Code:@ffmpeg.exe -hide_banner -filters > ff_filters.txt
No. This is not any news. Use the general forum if you don't know where to post.
Rescaling the Tinterlace filter outupt in FFMPEG
By JackyBorderCollie in forum Video ConversionReplies: 2Last Post: 4th May 2023, 15:40 -
Problems converting a clip to 10-bit using ffmpeg
By rgr in forum Video ConversionReplies: 25Last Post: 13th Nov 2022, 20:29 -
problems with mapping of livestream with ffmpeg
By Caidking in forum Video Streaming DownloadingReplies: 2Last Post: 15th Jul 2022, 17:29 -
Handbrake\ffmpeg blur-and-warm filter?
By andy_larkin in forum DVD RippingReplies: 0Last Post: 29th Apr 2020, 23:25 -
Equivalent of filter "Limiter" from Audacity in ffmpeg
By lenberg in forum AudioReplies: 1Last Post: 10th Oct 2018, 10:00
