HI GUYS,
I HAD A VERSION OF VIRTUALDUB ON PREVIOUS PC THAT GAVE ME THE OPTION OF
EXPORT: SINGLE FRAME AS AN IMAGE JPG STRAIGHT TO A FOLDER.
THE VERSIONS IVE TRIED DONT SEEM TO GIVE THIS OPTION.
DOES ANYONE ELSE HAVE IT OR SHOW ME HOW TO ALLOW IT AGAIN.
I DONT WANT A WHOLE IMAGE SEQUENCE OR SAVING TO A CLIPBOARD THEN OPEN IN AN IMAGE EDITOR.
I JUST WANT TO SAVE A SINGLE FRAME STRAIGHT TO A FOLDER.
ANY HELP VERY MUSCH APPRECIATED.THANKS.
VirtualDubMod lets you ave a frame as TGA, BMP, or PNG via View -> Snapshot... VirtualDub2 has File -> Export -> Single Image... which has a JPG option.
You can probably set it up as a hotkey if you're using it often (options => keyboard shortcuts)
Thankyou for your help much appreciated, ill try downloading virtualdub2 to get that option.
By Anonymous84 in forum EditingReplies: 1Last Post: 5th Feb 2023, 00:35 -
VirtualDub stuck on first frame - gone to 'possible livelock'?
By architectofpain in forum EditingReplies: 0Last Post: 22nd Nov 2021, 00:00 -
Virtualdub export image sequence "Access is denied"
By ecc in forum Video ConversionReplies: 5Last Post: 6th Jul 2020, 09:43 -
VirtualDub 4K Export
By jseo13579 in forum EditingReplies: 3Last Post: 21st Apr 2020, 11:50 -
Why frame numbers in VirtualDub and Avisynth different?
By Megafox in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2018, 12:56
