I have been trying to copy movies from my PC to iPhone. Unfortunately, I can't simply sync movie through itunes.
I have to convert it to MOV format with AVC (HEVC doesn't work on Apple TV?) and copy the same audio track.
However when I used AVIDEMUX and TENCODER to do this, the finished file loses the JOC/ATMOS content and turn into a normal 5.1 track.
I am not sure what I am doing wrong.
Secondly, also suggest some converter which can use my GPU to render H264 as I have to remux some HEVC file to H264 in order to play on iphone.
Attaching mediainfo of both files -
ORIGINAL -
Audio #1
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Duration : 1 h 36 min
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 530 MiB (20%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
AFTER MUX -
Audio #1
Format : E-AC-3
Codec ID : ec-3
Source duration : 1 h 36 min
Bit rate : 768 kb/s
Source stream size : 530 MiB (20%)
Language : English
Default : Yes
Alternate group : 1
mdhd_Duration : 5785204
Please help..
IF I am doing anything wrong, feel free to correct and share your input.
Copying movies to iphone is already a headache. I am doing this just to enjoy Spatial Audio on my Airpods.
You can try to remux only with clever Ffmpeg-GUI.
Load your mkv, click main, click multiplex, select mov as container, click multiplex.
Done. -
Tried it, but again it lose the JOC content and turn it into a 5.1 track
Audio
Format : E-AC-3
Codec ID : ec-3
Bit rate : 768 kb/s
Channel layout : L R C LFE Lsd Rsd
Language : English
Default : Yes
Alternate group : 1 -
Do .MOV files support Dolby Atmosphere ?
Convert mkv with Dolby Vision to UHD Bluray
By kallek in forum Authoring (Blu-ray)Replies: 19Last Post: 25th Apr 2024, 07:50 -
Convert DV mkv -> mp4 with mkvextract and dolby mp4_muxer
By jb044 in forum Video ConversionReplies: 5Last Post: 4th Mar 2022, 01:39 -
Convert mkv to m2ts without losing sound and picture quality
By certalic in forum Video ConversionReplies: 34Last Post: 20th Nov 2021, 06:05 -
MKV Dolby Vision encodes to MP4 ?
By Fuso in forum Video ConversionReplies: 2Last Post: 16th Mar 2021, 05:06 -
Converting MKV to VOB without losing quality
By guy24s in forum Video ConversionReplies: 9Last Post: 11th Apr 2020, 01:24
