How can we delete all empty lines and lines with music symbols in a subtitle file with Subtitle Edit with one click?
Subtitle edit/multiple replace/add your music note to find what and replace with blank and in fix common errors make sure remove empty lines is checked and in tools batch convert make sure those options i gave you are checked and you can apply this to multiple subs.
Thank you johns0. I managed to do so with your instructions. Two more questions:
The "Fix common errors" page has many bug fix options selected. I just want to delete the empty lines. Will having them selected cause any corruption in the subtitle file? So should I unthick them all?
Another question, not related to this topic, is it possible to compare 3 subtitle files at the same time? I know how to compare two at the same time (CTRL+SHIFT+O), but I want to compare subtitle files with three different languages, is that possible?
I had one more question, I forgot:
In the subtitle file that we open in Subtitle Edit, I don't want the lines to show, I don't know what it's called, code, <br/> />, etc. I want to hide them, when comparing subtitle files, is that possible?Last edited by Pusat; 9th May 2023 at 11:27.
subtitle edit is auto breaking lines
By cocowash in forum SubtitleReplies: 2Last Post: 8th Dec 2024, 15:33 -
Subtitle Edit manual spacing of lines
By loninappleton in forum SubtitleReplies: 14Last Post: 11th Sep 2022, 18:40 -
Subtitle Edit - Export to SUP: Lines are badly misaligned
By Sapito in forum SubtitleReplies: 0Last Post: 12th Feb 2022, 02:27 -
Delete or Replace Overlapping Subtitle Lines
By therealunno in forum SubtitleReplies: 0Last Post: 7th Sep 2020, 21:16 -
Subtitle Edit multiple lines: how to?
By lollozip in forum SubtitleReplies: 1Last Post: 15th Jan 2019, 14:58
