Is there a way to make Cedocida the default DV codec for Premiere in Windows 7?
I find myself capturing and editing some DV tapes on an old Windows 7 laptop running Adobe Premiere Pro CS5.5. My issue is that, when I try to export using Cedocida, it complete re-encodes the video, even when there are no effects or anything used. I'm sure that in my Windows XP days, I managed to get whatever version of Premiere I was using back then to essentially 'smart encode' my outputs, using Cedocida for the transitions and stuff that needed encoding, but otherwise letting all untouched video pass through unscathed.
Premiere CS5.5 will 'smart encode' using the default DV settings no problem; but can this be changed to the Cedocida codec instead?
Results 1 to 1 of 1
True bitrate for aq default 1.0 ?
By thekingintheall in forum Video ConversionReplies: 2Last Post: 26th Nov 2022, 07:54 -
How can I uncheck this as default ?
By pchan in forum FeedbackReplies: 2Last Post: 20th May 2022, 10:32 -
MP4 default volume
By Shadowflyer in forum Newbie / General discussionsReplies: 8Last Post: 10th Nov 2021, 17:32 -
Disable default subtitle
By marco000 in forum Video ConversionReplies: 16Last Post: 24th Jun 2021, 09:55 -
Aegisub default language
By Chris Allinger in forum SubtitleReplies: 0Last Post: 13th Apr 2021, 11:27
