I sure hope someone can help me here, this is the error I get: cce encoding failed: AVIStreamRead()failed(0x8004406d): A disk error occurred while reading the file. I have all the proper codecs installed, I am resizing and frameserving a divx avi with VirtualDub, I have stripped the vbr audio, I have shown VirtualDub a wav file. I have covered it all I think. CCE finishes the .vaf and gives a "cce encoding failed" then it starts the .mpv, about 2/3 through it crashes giving me the error at the top. Any suggestions? Thanks a bunch!
RiG
have you checked your divx file for errors? either use divxfix, or open with extended options in vdub, and rederive key frames, and save as new avi. that might do the trick
Two things come to my mind:
1. Did you install the patch that disable CRC check? If not, install it.
2. Always disable audio in your CCE template. -
Thanks Fantomlord, I've noticed throughout the forum that you are quite knowledgable, and thanks to everbody else for their suggestions!open with extended options in vdub, and rederive key frames, and save as new avi. that might do the trick
RiG
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 05:24 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
