Results 1 to 17 of 17
  1. Hi,
    Just wondering is it possible to obtain keys via cdrm-project.com or other means?
    Looking to rip the first season of Neighbours from Freevee:
    https://s3-iad-2.cf.dash.row.aiv-cdn.net/dm/2$HR_Xea-YY3SqvHqdF69DTCJMMqQ~/3353/71d3/fcca/4e54-8e74-e0c1fcb76636/f2016ff7-37cd-445a-8d4b-b1cd05ded14d_video_11.mp4?amznDtid=AOAGZA014O5RE
    I have the S01E1 pssh: CAESECHu0arLIUaWh3hp/mHlYUIaBmFtYXpvbiI1Y2lkOjVsYTBhREpFUzlDVVJhbTB3eGd BZWc9PSxJZTdScXNzaFJwYUhlR24rWWVWaFFnPT0qAlNEMgA=
    Any help to obtain the license url/headers much appreciated.
    Cheers
    Steve
  2. share mpd
  3. The
    CAES...
    is only part of the PSSH, you need a script to add the rest (or a lot of patience and copy/pasting to websites).
    The full PSSH (that has your base 64 decoded 'CAES...' data in it) is:
    AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQIe7RqsshRpaHeGn+YeVhQhoGYW1hem9uIjVjaWQ6NWxhMGFESkVTOUNVUmFtMHd4Z0FlZz09LEllN1Jxc3NoUnBhSGVHbitZZVZoUWc9PSoCU0QyAA==
    This is only the beginning though. You'll need to look at the request/response to the licence server and modify L3.py to do the same thing, you'll also need to make sure you are served the right mpd, the SD one (if you see an 'HD' symbol on screen when you stream from freevee then you've got the wrong mpd and the licence server will reject your request).
    It's a long time since I messed around with freevee, so things might have changed. But at least you have the right PSSH to start from now.
    Looking at the PSSH, it includes a track type, which is 'SD', so you might be getting the right mpd already.
  4. Originally Posted by stevepen1974 View Post
    Hi,
    Cheers
    Steve
    just for a test could you please try use to TubeDigger in RecMode i'm curious if it works for this site as well
    thx for trying
  5. It will not work with CDRM since there's additional challenges being made. You'd need a script.
    License server is:
    https://atv-ps-eu.amazon.co.uk/cdp/catalog/GetPlaybackResources....
    Headers are generic:
    headers = {
            'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/109.0',
            'Accept': '*/*',
            'Accept-Language': 'en-US,en;q=0.5',
    PSSH and keys for S01E01:
    PSSH: AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQbh0M5KpsTq6osKIzMS1AEBoGYW1hem9uIjVjaWQ6YmgwTTVLcHNUcTZvc0tJek1TMUFFQT09LFlkRkZSa0hUUy91ejdrQW5iUGlYTnc9PSoCU0QyAA==
    --key b770d5b4bb6b594daf985845aae9aa5f:b0cb46d2d31cf044bc73db71e9865f6f
    --key 6e1d0ce4aa6c4eaea8b0a233312d4010:aa293e7f42e48e08bd3c10a8c8af4b13
    --key 61d1454641d34bfbb3ee40276cf89737:36df6d7718f5bb1bcf72325016eb86ca
  6. @stabbedbybrick Are Android cdms still restricted to SD for freevee? Freevee doesn't seem to want to stream in SD for me at the moment.
  7. Originally Posted by bamboobali View Post
    Yeah, looks like it.
  8. Originally Posted by stabbedbybrick View Post
    License server is:
    headers = {
            'Accept': '*/*',
    Many thanks stabbedbybrick.
    Fails to decrypt:
    yt-dlp.exe --allow-u -N 6 "https://s3-iad-2.cf.dash.row.aiv-cdn.net/dm/2$HR_Xea-YY3SqvHqdF69DTCJMMqQ~/3353/71d3/fcca/4e54-8e74-e0c1fcb76636/f2016ff7-37cd-445a-8d4b-b1cd05ded14d_corrected.mpd?amznDtid=AOAGZA014O5RE& encoding=segmentBase"
    as per:
    mp4decrypt --key b770d5b4bb6b594daf985845aae9aa5f:b0cb46d2d31cf044b c73db71e9865f6f enc_video.mp4 dec_video.mp4
    Tried the other 2 keys and does not decrypt. Presume one key is for audio and another for video?
    If you can confirm all is correct.
    Cheers
    Steve
  9. I can confirm that the keys are correct:
    [Attachment 70867 - Click to enlarge]
    Make sure you grab the correct mpd. And I'd highly suggest using N_m3u8DL-RE to make things easier. It will take care of downloading, decrypting and merging.
    N_m3u8DL-RE --key --key --key "MPD URL" -M --format=mp4 -mt --save-name "Title of video"
  10. @Silv3r I tried Tubedigger (trial version) in Rec Mode on this site to see if the HD streams were available.
    It didn't work for me.
    I used the 'Monitor Browser' option along with Rec Mode, files appeared in the Tubedigger video output folder but none were playable,
    It might be user error, I've never used Tubedigger before.
    Dec 2021
    england
    https://www.amazon.com/gp/video/detail/B0B8Q6H77C
    1080p - video_15.mp4
    --key 5ab2c1022b1e44799c992e8012184aa3:1bb3b26fa0aa3a12056dd5498e7527ed
    DDP2.0 - audio_26.mp4
    --key 4e58b937673149148af119d9f9b06ca6:7fed08912418a71b1a82d86a95b2f4f3
    General
    Format                                   : Matroska
    Format version                           : Version 4
    File size                                : 2.46 GiB
    Duration                                 : 23 min 30 s
    Overall bit rate                         : 15.0 Mb/s
    Encoded date                             : UTC 2023-05-21 20:47:10
    Writing application                      : mkvmerge v76.0 ('Celebration') 64-bit
    Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
    Video
    Format profile                           : High@L4
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Bit rate                                 : 14.8 Mb/s
    Width                                    : 1 440 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 FPS
    Bits/(Pixel*Frame)                       : 0.380
    Stream size                              : 2.42 GiB (98%)
    Default                                  : Yes
    Forced                                   : No
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : E-AC-3
    Format/Info                              : Enhanced AC-3
    Commercial name                          : Dolby Digital Plus
    Codec ID                                 : A_EAC3
    Bit rate mode                            : Constant
    Bit rate                                 : 224 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 SPF)
    Stream size                              : 37.7 MiB (1%)
    Language                                 : English
    Service kind                             : Complete Main
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Bit rate                                 : 81 b/s
    Frame rate                               : 0.397 FPS
    Count of elements                        : 560
    Stream size                              : 14.1 KiB (0%)
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Mar 2006
    General
    Format                                   : Matroska
    Video
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : E-AC-3
    Codec ID                                 : A_EAC3
    Bit rate                                 : 224 kb/s
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Bit rate                                 : 81 b/s
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    I have been trying for a while to get this. I can get the PSSH from the init, convert to HEX, take the portion of HEX
    "PSSH header is always 000000xx70737368 - xx is changeable, here it is 34 and you will take 6 zeros before it."
    I take that and convert back to base64, and do get a PSSH which is:
    AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQWrLBAiseRHmcmS6AEhhKoxoGYW1hem9uIjVjaWQ6VGxpNU4yY3hTUlNLOFJuWitiQnNwZz09LFdyTEJBaXNlUkhtY21TNkFFaGhLb3c9PSoCU0QyAA==
    Which is close, but not the same as PSSH from example above, which is:
    Either way, with either PSSH, I am trying to run with my cdm.
    D:\free>python l3.py
    License URL: https://atv-ps.amazon.com/cdp/catalog/GetPlaybackResources?deviceID=b547ad1f-eb62-4bf0-b8cd-aef714e6aa9a&deviceTypeID=AOAGZA014O5RE&gascEnabled=false&marketplaceID=ATVPDKIKX0DER&uxLocale=en_US&firmware=1&playerType=xp&operatingSystemName=Windows&operatingSystemVersion=10.0&deviceApplicationName=Chrome&asin=B0B649M2CH&consumptionType=Streaming&desiredResources=Widevine2License&resourceUsage=ImmediateConsumption&videoMaterialType=Feature&clientId=f22dbddb-ef2c-48c5-8876-bed0d47594fd&userWatchSessionId=f8355033-8674-4f9d-b637-7778c6ab30d7&deviceProtocolOverride=Https&vodStreamSupportOverride=Auxiliary&deviceStreamingTechnologyOverride=DASH&deviceDrmOverride=CENC&deviceAdInsertionTypeOverride=SSAI&deviceHdrFormatsOverride=None&deviceVideoCodecOverride=H264&deviceVideoQualityOverride=HD&deviceBitrateAdaptationsOverride=CVBR%2CCBR&playerAttributes=%7B%22middlewareName%22%3A%22Chrome%22%2C%22middlewareVersion%22%3A%22115.0.0.0%22%2C%22nativeApplicationName%22%3A%22Chrome%22%2C%22nativeApplicationVersion%22%3A%22115.0.0.0%22%2C%22supportedAudioCodecs%22%3A%22AAC%22%2C%22frameRate%22%3A%22HFR%22%2C%22H264.codecLevel%22%3A%224.2%22%2C%22H265.codecLevel%22%3A%220.0%22%2C%22AV1.codecLevel%22%3A%220.0%22%7D
    unable to parse license - check protobufs
    I tried to have headers.py with everything from what I captured with curlconverter, also just tried the simple generic headers stabbedbybrick posted
    headers = {
            'Accept': '*/*',
    my cdm has not had issues elsewhere, so I am wondering am I doing things wrong here for this example?
    Dec 2021
    england
    stabbedbybrick did wrote there's additional challenges being made. You'd need a script.
    Mar 2006
    I know, and I guess that is the part I do not know. I am not good with any kind of scripting. Any info on this?
    What would I need, if I could figure it out what am I looking to capture with the script?
    I am sorry, my line of questioning is very vague, I honestly do not know what I am looking for.
    Dec 2021
    england
    if you use andriod l3 cdm, freevee will give upto 576p keys (i think), i have chromecdm which it will give upto 1080p keys
  16. Originally Posted by ehurdler View Post
    Passing just PSSH and simple headers only work for services with a simple setup. What you need for Freevee, among many others, is to post the request with a properly structured JSON payload that includes a challenge generated by your own CDM, and some additional account data. If you right-click the license, copy as cURL, and paste it on curlconverter.com, you'll see more clearly what it could look like in Python code, which is the language being used in your "l3.py". The important bits here are the data and cookie parameters. And then you'll get a JSON response back that you need to handle.
    To understand these concepts and write your own scripts, you'll need to learn some programming. There's no way around it. Even if someone gives you a working script, using them without knowing why they work is going to lead to serious frustrations when things break. Luckily, there's a massive community surrounding Python, so learning it only requires some dedication on your part.
  17. If you 'unquote' your license url:
    print(requests.utils.unquote("https://atv-ps.amazon.com/cdp/catalog/GetPlaybackResources...all the way to the end"))
    It contains:
    I suspect (but I don't know) that this request is trying for 1080p, so (I suspect) it won't work with your Android CDM.
    Possibly someone who can get the SD mpd could confirm.
