I'd be grateful for any feedback from Windows 11 users who have the GV-USB2 or the USB Live 2.
Do they still work OK?
I'm considering an OS upgrade from Win 10 to 11 but want to check if these gadgets still function on 11.
Thanks for any input.
Results 1 to 10 of 10
Either works here.
Don't take this as a recommendation. I can only speak for my system. -
Thanks Sharc, one report becomes a couple, a couple becomes a few and then we know.
Here the couple. I am on Windows 10, but have some friends using GV-USB2 or the USB-Live 2 with success on Windows11. Latest drivers version used for both.I'd be grateful for any feedback from Windows 11 users who have the GV-USB2 or the USB Live 2.
Don't take this as a recommendation, I am just reporting from others (just checked their captures were ok). -
Just bought this stick and it works with Windows 11 like a charm.
I just came across your thread about different driver versions and I am considering using 1.11, if this works better for VHS.
Greetings from Germany -
There doesn't appear to be any quality difference between the driver versions; the only issue is that with the 1.12 (and 1.14) version, 25fps is not available in the "Format Preset" list in AmarecTV, but it can be typed in to replace 50fps on the "Format" line.
I upgraded to Win 11 a few months ago, and my GV-USB2 is working just fine. No issues at all. Haven't tried USB Live2 myself, but I've seen others say it works without problems too. I'd say go for the upgrade
Thanks for reply.
Just checked the manufacturer site about version 1.14 but I think there was only something changed about the capture program "LightCapture". -
[Attachment 79923 - Click to enlarge]
Installed the driver from upddate Ver.1.14(2024/04/03).
https://www.iodata.jp/lib/software/g/1780.htm#Windows%2011
It is the same. Device manager : 1.1.0.193 (07.06.2021)
Hauppauge USB-Live2 vs IO Data GV-USB2
By anachronon in forum Capturing and VCRReplies: 14Last Post: 3rd Nov 2023, 22:09 -
Both Diamond VC500 and IO GV-USB2 do not work on clean Windows 10 install
By bigbadben in forum Newbie / General discussionsReplies: 23Last Post: 14th Nov 2021, 06:30 -
USB-Live2 worse quality than EasyCap
By videonewb in forum Newbie / General discussionsReplies: 24Last Post: 1st Aug 2020, 14:11 -
USB-Live2 Proc Amp Settings in VDub Don't Work
By koberulz in forum Capturing and VCRReplies: 26Last Post: 5th May 2020, 15:44 -
Hauppauge USB-Live2 not working in virtualdub
By BillyJeanB in forum Capturing and VCRReplies: 16Last Post: 24th Nov 2019, 04:34
