  1. Anonymous
    Guest
    Mar 2008
    Have you tried Virtualdub2 ?
    It opens and can save to many more formats
  3. Anonymous
    Guest
    Mar 2008
    There is an mp3 encoder, it's the FFmpeg Lame MP3.
    Direct stream copy does work differently, it uncompresses the audio (PCM/wav) and writes that out when direct is chosen.
    (That's why it's so big) I don't know a way around that but somebody may know definitively.
    It can be worked around, For example, you can turn off the audio in vdub2 and then re-add it later using MKVtoolnix
    to create an MKV file using the new video and the old audio
    Using File/export/stream copy (in vdub2) will copy the selection as-is, both video and audio
  5. Anonymous
    Guest
    Mar 2008
    "ffmpeg Lame mp3" is one of the built-in items, doesn't need any external files,
    it's in the list in the image you posted above - so not sure exactly what you encountered...
