How can i make nero 5.5.8.0,to burn a text and picture before the
movie vcd.!!
Thanks from greece!!
Under Nero when you create a VCD select the Menu tab and check enable menu. This will create a menu with which you can select the videos. You can specify a backgroud picture and the items can either be text or a thumbnail.
I was able to figure out this process fairly easily, with one of two test burns onto CD-RW.
If you have any further questions you are welcome to ask. -
You can also browse the title you made before you burn .
To do this once you have loaded in your mpeg/dat file etc.. you will see your title at the top simply double clik or right clik select properties and you will be shown what your title will look like. the only problem is however if it is NOT the way you want it you will have to start from scratch making your title and dragging and dropping your mpeg in once again. But this means you are NOT wasting discs then finding the title is'nt the way you want it, hope this helps.
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 10:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 13:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46
