I compress a lot of 1080p home videos using VidCoder x264 at CRF 26 at very slow speeds, which does a pretty good job of saving me space. The video quality is good and the file size is a fraction of the original. However, I've been thinking of using x265 instead since it provides even better compression and still good or even better quality, but I don't know which x265 settings to use.
There's:
H.265
H.265 10-bit
H.265 12-bit
H.265 (Intel QSV)
H.265 (NVEnc)
With x264, I use CRF 26 on 1080p videos, but CRF values are different with x265 so I don't what setting to use to keep a comparable quality.
Which of those should I use to keep at least the same video quality as what I'm currently using but with better compression to produce smaller file sizes?
I leave my videos encoding over night, so more compression while maintaining good quality is more important than speed.
My computer specs are as follows: i7 processor, 2.60 GHz, 16 GB RAM, 2 cores.
Use h265 (8 Bit, for compatibility with many devices) and CRF 30
Is x265 12-bit slower or faster? Does it compress better? I'm more concerned with smaller file sizes than compatibility.
In my experience most devices that play 8 bit 4K HEVC also play 10 bit 4K HEVC.
H.265s main (10) profile contains 10bit, which is the reason my normally all devices support 10bit,....
AVC, h.264, MPEG4-Version10, h.265 MPEG-H
By Litaiff in forum EditingReplies: 5Last Post: 22nd Feb 2023, 23:42 -
Differences between ripping H.264 and H.265
By vieekk in forum Video ConversionReplies: 10Last Post: 23rd Dec 2020, 22:33 -
Batch convert H.265 MKVs to H.264
By Nico Darko in forum Video ConversionReplies: 2Last Post: 28th Jun 2020, 18:09 -
period for video convertion from h.264 to h.265 nvidia 2080
By empleat in forum Video ConversionReplies: 2Last Post: 7th Mar 2019, 11:12 -
264 or 265 encoder 10bit input format
By CommanderLake in forum Video ConversionReplies: 3Last Post: 12th Jul 2018, 18:31
