Results 31 to 33 of 33
First to downscale the jpsdr's plugins and in 2023 the test AVS+ cores have special kernels resizers with adjustable 'sharpness/look/makeup'. It is SinPowResize(MT) - p-param to adjust sharpness and UserDefined2(MT) b,c,s params to adjust. So may be no more required to use 'static image' resizer kernel like Spline + sharpener (also single pass frame processing with resampler only may be faster).
About degrain in larger size: The mvtools (2.7.45 and post-2.7.45 partially) have not enough precision for fetching UV planes blocks for subsampled chroma formats. Latest fixes in post-2.7.45 builds only center the error but not completely fix. To use best precision user need to convert to 4:4:4 format before processing. So degrain in larger size (2x) act as additional pel_x2 multiplier and helps to create less distorted result decreasing spatial fetching error by half.
Though depending on real content details/sharpness and block size it may be or may not be better in motion search quality. Because typically 4K footage may be simply soft filmscan and small block size search may have less details to reference and produce more long striked MVs. It may be also better to use half sized frame to MAnalyse and to perform MDegrain denosie in original 4K size after MScaleVect/+ optional MRecalculate). All depend on footage sharpness and noise levels.
Multi Rate HEVC Encodes for 720p/1080p/2160p
By mukeshsinh in forum Newbie / General discussionsReplies: 0Last Post: 29th Jul 2021, 09:22 -
Best Way To Downscale 1080p 30fps Sports Video to 720p for Bluray?
By AndersonJames in forum RestorationReplies: 10Last Post: 18th Jun 2020, 14:25 -
Best FFmpeg command for downscaling h264 video from 2160p 1080p?
By jorax68528 in forum Video ConversionReplies: 3Last Post: 12th May 2020, 19:52 -
How do I downscale a 4K video to 1080p Bluray quality?
By SomeoneNeutral in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Sep 2019, 19:13 -
Why AVC looks better than 10-bit HEVC with same CRF
By vash1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Nov 2018, 07:53
