Currently im upscaling Anime with 2 Models in a row (LD-Anime Compact + FutsuuAnime Compact). But because this takes very long, i'am searching for a filter-method, which does "filter-up" the upscaled Anime only with one model (ld-Anime Compact). So that i dont have to use the second model, which takes very long time.
I already tried out a bit and i get decent results. Here is a comparing of LD-Anime Compact, LD-Anime comapct + FutsuuAnime Compact and LD-Anime Compact + Filters: https://imgsli.com/MTc2MDYx
I used this filters:
- Thin- and Darken GLSL A4k (in Hybrid Vapoursynth-line) with 0.4 and 1.3 strength and HQ
- Then DAAMod (in Hybrid Vapoursynth-line) with Nsize 8x4, NSS 256 and PScnr old (need help with that)
- Then CAS GLSL (in Hybrid Vapoursynth-sharpen) with "better dialog" and "accurate"
Rest ist default.
My question is now:
What do you think i can optimise ? Like use another AA or another Sharpener (no aWarpSharp or similair pls). Did i use the best of it's class ?
Or the specific settings in the filter (like in DAAMod: Ist it better to have a low-number NSize ? Is it better to use PSCNR "old" if you want to have best possible quality? Is it better to use more NNS ?)
So to clarify: i want to reach the quality/sharpness, of the LD-Anime Compact + FutsuuAnime Compact picture
I would really appreciate your help.
Have you tried AnimeSR?
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Tried it now but it gives me 0.5FPS on an 1080p source ( i do first ld-anime compact from 720p to 1080p).
I want to avoid using FutsuuAnime Compact, which gives me (at the same source) also only 0.4FPS. It is another source than i used in other threads, where i got more fps. I dont know why actually. Different sources but both has 1080p input and on the one i get 4.1FPS and on the other i get 0.4FPS. Strange. it's 10 time slower but same inputresolution.
You know any method without models (they are mostly slower than filter/ non-AI Stuff). Or do you think, sth. on my settings (for example on DAAmod AntiAliasing is optimize-able ?).
AnimeSR crashed when i use Tensor btw. -
Works fine here, but eats lots of vram,.AnimeSR crashed when i use Tensor btw.
Settings are always optimize-able.users currently on my ignore list: deadrats, Stears555, marcorocchini
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
help improve the radiohead's "fake plastic trees" music video
By rrats in forum RestorationReplies: 6Last Post: 22nd Jan 2023, 16:22 -
How to correct "fake FPS"
By ridibunda in forum EditingReplies: 11Last Post: 26th Feb 2022, 13:54 -
[After Effects] Directional sharpen effect for ae? Like PS "Smart Sharpen"
By zkri in forum EditingReplies: 2Last Post: 2nd Feb 2021, 07:59 -
DVD "fake" 5.1 DTS is actually stereo... how to fix empty channels?
By Sapito in forum AudioReplies: 1Last Post: 3rd Jan 2019, 04:31
