Hello, sorry for the noob question. I just started using VSDC.
I wanted to use 3 transform video effects (Zoom, Crop and Movement) on a video (of a narrator) to make it smaller and move to the corner of a larger video (of the subject).
It looked fine in the workspace and Preview. However, when I exported the video, only Movement worked as intended.
Crop still worked but very slowly - it took 10+ seconds, where as I set it to 1 second - and Zoom didn't work at all.
I started a new project, imported different videos and tested one transform at a time. The result was the same. Everything was fine in the preview. In the exported video, movement worked, crop was very slow, zoom didn't work at all. I also tested Rotate and Shift. They also worked in the preview, not in the exported video.
I'm not sure what I did wrong. Any help would be appreciated. Thank you!
Did you ever figure out the solution for this. I'm experiencing the same issue and it's so frustrating. I've spent over 6 hours tweaking a ton of settings just trying to get the video the export with the zoom effect working. What's the point of the video preview if the final export doesn't match it at all?
About VSDC Video Editor!
By Valentin98 in forum Newbie / General discussionsReplies: 0Last Post: 13th May 2022, 02:51 -
VSDC Video editor video frame preview on timeline
By jay11421 in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2021, 06:33 -
VSDC Video Editor will no longer save projects
By Canker in forum Newbie / General discussionsReplies: 0Last Post: 8th Jun 2020, 20:09 -
Video is choppy and slowed down after editing with VSDC Editor
By casino998 in forum EditingReplies: 0Last Post: 7th Mar 2019, 16:58 -
VSDC Free Video Editor - Secondo video in trasparenza sul primo
By OTMAN in forum Newbie / General discussionsReplies: 0Last Post: 6th Mar 2019, 07:56
