I bought very cheap DVD-RW discs $2.39/disc (in a 10-disc pack) at www.hypermicro.com. They work perfectly in the Pioneer DVR-104 drive but not in my HP Pavilon n5125 notebook's DVD-ROM drive.
Do you have any experience with the DVD-compatibility of these "hypercheap" generic DVD-RW discs?
Have you played any other brand discs on your laptop?
My Tosheba won't play ANY DVD-R/RW discs. -
leebo is right. Check and make sure that your drive can play branded dvd-rw's. I bought generic dvd-r's from hypermicro and they play fine on my Affree dvd-rom drive but the verbatim dvd-rw I bought from hypermico does not. Its the drive's fault not the media. [/b]
Hypermicro's DVD-R and DVD-RW do have some problem. They are a little bit heavier...and my experience is that, the DVD-R can be played on my DVD-ROM drive of my desktop, but not playable on my notebook's DVD-ROM, and not playable by my Sony DVD-player.
I haven't tried the DVD-RW yet. Will post results after I tried. -
Thanks a lot for the comments!
In the meantime I found that it does not matter what DVD-RW media I was using. I tried Pioneer ($17/disc), Sony DVD-RW ($13/disc) and hypermicro generic ($2.4/disk) discs and none of them worked with any of the notebook DVD-ROMs I tested.
LanceSteel is right "Its the drive's fault not the media.".
However, all notebook slim DVD-ROM worked with DVD-R discs. -
Its just like CD-R and CD-RW was back in the day... if its new enough it can read it unless its a cheapo drive ... in time everyone will forget all these bumps in the road and everything will be good...
Some machines will read DVD-RW fine regardless if DVD-RW support is listed or not. But if you want to ensure maximal compatibility, use your drive to burn DVD-R instead on GOOD media.Originally Posted by nemethmik
incompatible recording between DVD recorders?
By hillneerg in forum DVD & Blu-ray RecordersReplies: 11Last Post: 7th May 2010, 12:23 -
Are DVD-R/DL (double layer MINUS R) incompatible with ISO/MDS for +R/DL?
By miamicanes in forum DVD RippingReplies: 16Last Post: 31st Dec 2009, 22:24 -
Pioneer DVR-220S and TDK (CMC MAG, AM3) discs incompatible?
By cwerdna in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Nov 2008, 16:25 -
DVD Fab incompatible with DVD Shrink
By JohnnyBob in forum DVD RippingReplies: 14Last Post: 14th Sep 2008, 20:59 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 20:07
