I have this VOB file of a music video that seems to be heavily blended (original was 50i/25i converted to 29.97i through some weird blend).
I have tried everything i could think of in AviSynth to minimize blending to no avail.
I´ve tried
I've also triedCode:Srestore(25) QTGMC()
Those are all the ways i could think of removing that blend. Below is a 20 second clip cut using ffmpeg (-c copy) with no reencoding at all so you can see the blend.Code:Tdecimate(mode=7, rate=25) QTGMC()
If anyone knows how this blend could be removed in AviSynth i would appreciate it.
samplevob.vob
first time I see someone apply srestore or tdecimate beforce qtgmc, normally one would use it the other way around,....
have you tried something like
QTGMC()
some deblocking and denosing
sRestore()
?users currently on my ignore list: deadrats, Stears555, marcorocchini -
Your best bet is probably to start with:
Code:QTGMC() sRestore(frate=12)
There are tons of blends (probably, some are intended), if you can't get git of them with sRestore with frate=12 and neither with ExBlend, you probably can't get rid of them without manually editing frames.
Restoring/ compensating overexposed, heavily clouded weather, video's
By Rockel83 in forum RestorationReplies: 35Last Post: 25th Jul 2022, 17:13 -
Blended frames removal
By T0biasCZe in forum Newbie / General discussionsReplies: 7Last Post: 9th Apr 2022, 17:17 -
Multi-line, heavily stylized subtitles (ASS) possible on Blu-ray?
By Deli295 in forum Authoring (Blu-ray)Replies: 12Last Post: 25th Jan 2021, 15:41 -
Is there anything better than srestore to deal with this blended source?
By bruno321 in forum RestorationReplies: 1Last Post: 8th Mar 2019, 02:43 -
Source is heavily compressed, and telecined.
By attackworld in forum EditingReplies: 2Last Post: 31st Jan 2019, 07:55
