Results 1 to 11 of 11
  1. I am running this command to download some live stream:
    ./N_m3u8DL-RE https://live4-ott.izzigo.tv/out/u/dash/DE-PELICULA-HD/default.mpd --key 70a3ab1ea3c45dd570da2a660ae5eeda:0a9db0e08d0b737e6 a64ecaed525d4cb -M format=mkv --live-record-limit 02:00:00 --live-real-time-merge --use-shaka-packager --live-pipe-mux
    The resulted mkv and ts file have audio out of sync. When looking at the media info, I see video frame rate is 30 fps and audio is 23.438 FPS (2048 SPF).
    I also see:
    21:41:41.079 INFO : Selected streams:
    21:41:41.080 INFO : Vid *CENC 960x540 | 2670 Kbps | video=2670000 | avc1.4D401F | 31 Segments | ~01m02s
    21:41:41.080 INFO : Aud *CENC audio_147682_spa=147200 | 147 Kbps | mp4a.40.5 | es | 2CH | 31 Segments | ~01m01s
    Can you help me fix that?
  2. Banned
    Apr 2022
    Hong Kong
    Which version are you using right now?
    It came to me that when I was recording (downloading) HLS-stream live, the video and the audio didn't match perfectly.
    And in the latest v0.1.6-beta the problem I mentioned has been fixed.
    Also, try 'not adding' the -M format=mkv command, and just use mp4decrypt instead of shaka and see what's coming out.
  3. I am using N_m3u8DL-RE (Beta version) 20230412
    I will try your suggestions and let you know.
    Edit:
    I still have the audio sync issues.
  4. 'pelicula'.
    'N_m3u8DL-RE' will not be able to correctly download content from this resource.
  5. Originally Posted by LZAA View Post
    'pelicula'.
    Why not?
  6. Originally Posted by LZAA View Post
    Can you fly?
    Can you please refrain from those ridiculous answers? You are saying it is not possible without saying why? And I said in my message I can download the stream, but the audio isn't synced with video. So it is clearly possible.
  7. Again, you are posting a nonsense messages without giving details. I didn't ask to download me that stream. Why are you doing that?
    Also, I find out that sometimes the audio is in sync (same command).
  8. So after some digging I noticed that the audio has 2s more than the video, so I just removed them when merging manually.
  9. Originally Posted by Mrachan View Post
    i suggest not use "--live-pipe-mux" , and use -M format=mp4 , not mkv, and append this "--append-url-params --mp4-real-time-decryption".
